what a good plug to use
what is a better plug to use than
ngk had a new set put in when the bike was being work on and have already fowled them in about 1000 miles |
RE: what a good plug to use
Is your choke stuck on? If you have removed the choke cable from the carbs lately, it's not difficult to reinstall it in such a way that it won't close completely.
the choke is working fine i check it and same to be ok
do you think if i run hotter plug it would do better thanks for the help |
I have been running a set of NGK iridum spark plus for 25,000km with no probs.
They have only now started to foul because of bike running rich. Probably carb problem above or floats. |
GM, I got your PM but had trouble replying. Hope everything is going ok for you. I'll keep an eye on the mailbox...
Thanks for staying in touch. Jason |
