Suspension question
Old Nov 8, 2007 | 11:10 AM
Noe's Avatar
Noe
Default Suspension question
I'm considering to upgrade my suspension this winter. The forks are now 11 years old, and probably with the original oil still in them, so it's getting a bit saggy in the front...
How do Ireplace the springs and oil? and what is a good alternative to original springs? can I make the front better then original with aftermarket springs and oil?
Noe
Old Nov 8, 2007 | 12:23 PM
Faergen's Avatar
Default RE: Suspension question
About replacing springs and oil, it´s discribed in the Haynes "Honda Cbr600f1 And 1000f Fours Service And Repair Manual". Costs 280 DKK (with free delivery) and is worth it.
http://www.saxo.com/item/508965
Price is about 400 DKK at a bikeshop.
Old Nov 8, 2007 | 04:03 PM
pacojoseph's Avatar
never mind
Old Nov 8, 2007 | 04:05 PM
BLUE1000F's Avatar
I havebought me Hyperpro front springs with oil included...a job i was planning to do the coming winter.
I thinkthis will upgrade my front suspension qiuet a bit cause it feels prettysoft.
Have you checked the service manuals here on the forum....?
And there is a post where we discussed this resently.
Old Nov 8, 2007 | 04:07 PM
BLUE1000F's Avatar
https://cbrforum.com/m_414711/tm.htm
Old Nov 8, 2007 | 04:09 PM
TWISTED METAL's Avatar
hyperpro springs and solid fork oil is not very expensive...just a bit of work....
Old Nov 8, 2007 | 05:01 PM
collector's Avatar
Hi Noe. You can do this with the forks in situe. Loosen front wheel and place a jack under the engine to lift the front up. remove wheel. At top end of forks release the air pressure and undo the caps, taking care as the spring and collars are under pressure. Remove srings. Using an alan key undo the lower bolt from the botton of fork leg, and allow oil to drain into a large bowl. You can move the lower casing up and down to get all the oil out. Next pull the lower down to seperate it from the top end and remove old seals. Empty the conents of attatchment from inside the lower fork out for cleaning.
You can upgrade to a heavier spring, and heavier grade of oil,but this will change the handling of the bike. Renew the lower copper washer as a matter of corse, with new sealsand reasemble. Dont forget the replace air into the forks.....6psi in each.
Old Nov 8, 2007 | 05:08 PM
Trips's Avatar
I would seriously reccomend paying the $$$ and upgrading to Racetech Gold Valves. It really will make the fork seem much better.
Zachbw55
Mar 27, 2013 06:56 PM
cbrmurphy
Nov 10, 2008 01:03 AM
Noe
Jul 6, 2006 09:57 PM
redliner
Apr 2, 2006 04:51 AM
lfcalc
Jan 31, 2006 06:22 PM
