Sub Air Cleaner Filter
Old Jan 17, 2013 | 03:24 PM
mjp94cbr100f's Avatar
Default Sub Air Cleaner Filter
just an fyi for all who work on their 1KF carbs. beware of the replaceable sub-air cleaner filter that disinigrates with age and pieces of filter material end up under slide diaphram. the filter hsg has one 10mm bolt, is black plastic and is bolted to a bracket under the tank by the r/f area of the frame. i made my own replacement but also found the oem is available for $2.08 at the stealership. its easily removed, so i would check it. its #13 on the diagram.
http://www.servicehondapsn.com/fiche...94&fveh=132679
Old Jan 17, 2013 | 07:15 PM
Sprock's Avatar
uh huh thanks it's in other carb' threads
Old Jan 20, 2013 | 07:07 AM
ranchome's Avatar
I've looked at mine when I've done te valve adjustment. It's the original and looks like new! Maybe I should replace it as a matter of prevention.
Old Jan 20, 2013 | 07:58 AM
TimBucTwo's Avatar
Actually, Sprock and I were victims of that a few months ago. Unbenounced to each other, we each used a piece of Scotch Brite pad with a little oil, to make a new filter.
Old Jan 20, 2013 | 08:25 AM
ranchome's Avatar
Sounds like a pretty good solution. But for the cost OEM sounds like the ticket
Old Jan 20, 2013 | 12:38 PM
Default +
+1 on the scotch pad. thats what i found around the house but wasnt sure about the density and since its to the carb, i ordered an oem for the 2 bucks. its probably worth .02 cents, but i feel better about it. that filter is right over the heat of the engine. i guess like minds think alike lol
Hyperblau
Mar 21, 2012 07:15 PM
usndocjaysin
Sep 21, 2007 10:18 AM
Tripwire25
Aug 6, 2007 11:16 PM
ninetyfivehp
Jun 13, 2007 05:44 PM
ddvs
Sep 11, 2006 04:05 PM
