Starter Clutch
Old Feb 15, 2008 | 11:25 PM
mdf21's Avatar
Default Starter Clutch
Hi all, i have a 1988 Cbr 1000that has done27000kms.I have had this bike for 3 years, latelywhen i attempt to start the bikewhen the engine is cold, the starter clutch makes a crunching soundand this happens several times before it eventualy starts and runs normaly.When trying to start the bike when the engine is warm, it starts fine without no crunching. This same thinghappened about2 years ago and i replaced the starter clutch, wasn't much fun as the engine had to come out and the crankcase split.I couldn't get a exact replacement part and had to get a superceded part which was almost the same. How long should a starter clutch last? Could there be something else that is causing this starting problem?As a reliable Honda the bike has never not started for me but it is just a bit embarassingto start the bike and it makes this loud crunching sound, anyinfo, advice would be much appreciated.Thanks in anticipation!
Old Feb 16, 2008 | 10:41 PM
Shadow's Avatar
Default RE: Starter Clutch
It may be the springs in your starter motor have lost a bit of their tension.........my wife's old CB750 had that problem - we took the starter out and gave the springs a pull to lengthen them
(cheapskate, yeah I know) and sorted the problem. Another cause could be misalignment of the teeth, but not likely or it'd grind all the time.....
Sorry, best I can do without actually hearing it.....
street600
Jul 25, 2008 08:43 PM
MrEarbrass
Oct 19, 2007 07:42 PM
druncle
Sep 13, 2007 04:03 PM
vulcanman72002
Apr 20, 2007 09:13 PM
HonknRalph
Jun 2, 2006 10:27 PM
