Squeak in front end
Old 09-24-2013, 07:49 AM
hillbilly86's Avatar
Default Squeak in front end
For a couple weeks now I've been hearing a squeak coming from the front of my bike. If you know what a bearing sounds like when it's going bad, it's that type of squeak (doesn't take long for it to get annoying)
I'm familiar with the sound so my first thought was the front wheel bearings were going bad, ordered a new set, installed them 5 days ago, still have the squeak.
My next guess would possibly be the steering stem bearings, but I'm not certain. As I'm going down the road I can hear it, jump on the gas and it can be heard a little better, let off the gas and it goes away.
Thought that it might be something internal in the engine but just sitting there at idle and when jumping up the rpms steadily or suddenly I hear nothing so that eliminated that thought from my mind, but I'm still not sure if it would be the steering stem bearings or if maybe that it's something in the forks.
Handling hasn't changed at all, going into a corner, in a corner, exiting a corner, and then transitioning into another corner it still feels as stable and confident as the day I got her.
Old 09-24-2013, 08:05 AM
wheelnut's Avatar
Welcome Crew
have you tried pumping the forks up and down whilst stationary to see if it is the forks(bushes), whilst stationary try the steering head bearings, if that fails block up the bike so you can spin the front wheel to see if you can pinpoint the squeak) could be the speedo drive needs greasing
Old 09-24-2013, 04:20 PM
TimBucTwo's Avatar
That's odd. What happens if you slightly pull the front brake lever? I wonder if the front pads are squeaking.
With bike on center stand and in gear, check speedo cable for squeak maybe.
Old 09-24-2013, 08:44 PM
Sprock's Avatar
I'd be going with TBT's idea - brakes pads binding
Old 09-24-2013, 09:34 PM
well I know it's not the speedo cable as I have no speedo cable haha, the aftermarket instrument cluster I have uses the magnet sensor setup. I'll have to wait till in the morning to try everything, I work 3rd shift so I've been asleep all day but I'll try it out and see what results I get
And thanks guys for the quick responses
ellis cbr fx
05-12-2014 06:07 PM
Reed13
04-12-2013 09:02 PM
TheTussin
03-07-2009 07:20 AM
EHonda
04-26-2008 12:10 AM
Bake13b
05-28-2006 10:03 PM
Quick Reply: Squeak in front end
