Slow indicator
Old Sep 23, 2008 | 05:09 PM
TimBucTwo's Avatar
Default RE: Slow indicator
ORIGINAL: Shadow1
Earthed and grounded not the same ?
Hmmmmmm - must be an Oz thing.
Have to Google it
Glad you found it Coopz -
Earth and ground are the same as far as I know. It depends on where you are from.
Old Sep 23, 2008 | 10:11 PM
MarkR's Avatar
Think of it this way Shadow1
I have a radio sitting on a stand, takes 4 AA battery's so 6-volts.
The negative of the battery is grounded to the chassis of the radio and that’s touching that metal stand that it's sits on, so the radio is grounded.
If I put a another radio next to it, touching the metal stand, that is grounded and they share the same ground.
The stand has rubber feet, but I decide to put a 9-volt battery between the stand and a wire that pokes into the dirt outside. So my 9-volt battery is earthed with the +9volts is going to the stand.
If I get a meter, the radios are 6-volts, but if I Earth the meter's black probe to a peg outside, I get 15-volts, cause I have just earth the meter, where before, it was just grounded.
That’s how I see it, I also used Mr Google to make sure I was right
Bottom of http://amasci.com/amateur/whygnd.html was the best I could find
Cause I am downunder, we see -15v not +15v, we ride on the other side of the road, our beer is cold, our toilet water spins the other way, and a sidewalk is a dance move or a sign of drinking too much cold beer.
Old Sep 23, 2008 | 10:21 PM
Shadow's Avatar
As I said, it's an OZ thing.......
You just want to confuse use with your indesputable logic......
However, I submit that grounding is an American term, which refers to being held inside a house (generally IRO teenagers), and therefore
Your fridge would be grounded (it ain't going anywhere), and your bike is earthed
Your bathwater also makes whirlpools the same way as ours, we drive on the left, which is right, and being negative not positive is def an OZ thing - pity you blokes can't play rugger, either.... A sidewalk - dance move ? Nah, its a PAVEMENT
Most of our portable radios are plastic, and they still play when picked up off the table.........
he he - enough, already !! He's FIXED THE PROBLEM
Old Sep 23, 2008 | 10:43 PM
MarkR's Avatar
You still missed it, the bike is grounded and the fridge is earthed (green/yellow wire)
we are not negative, we are netual (blue wire)
Old Sep 23, 2008 | 11:10 PM
Shadow's Avatar
[sm=icon_cheers.gif]
Bugger it, let's have a beer, we'll sort it out later.
Old Sep 23, 2008 | 11:34 PM
MarkR's Avatar
That would be a Cood Beer, sounds like a good idea
Old Sep 24, 2008 | 12:36 AM
Shadow's Avatar
Izzat spwlt korrektlee ?
Koala Bear ?
We'll crack a few tinnies at the next barbie, Mate !
Public holiday today - gotta run - riding in 30 mins now 7.36AM local time......
Juliet
Jan 1, 2010 06:48 PM
Junior
Oct 31, 2009 01:19 PM
f3BikeR
Jan 2, 2009 06:22 PM
jaynd
May 11, 2008 07:40 AM
mermark
Jun 21, 2007 11:37 PM
