Slow indicator
Old Sep 19, 2008 | 06:48 PM
Coopz's Avatar
Default Slow indicator
Strange problem has come up in the last week or 2. When I click my right indicator on, it takes sometimes, 2-3 seconds to come on, it works fine other than that, and the left one comes on instantantly.
Any help would be welcome.
Old Sep 19, 2008 | 08:17 PM
Naga_Thai's Avatar
Default RE: Slow indicator
Hi Coopz - this usually blown indicator globe or poor earthing in that indicator side.
[ol][*]Check both globes on that side are working.[*]check the earth lead - front and back for that side.[/ol]
Coopz please email me a contact number - i might take a flying visit Melbourne to Adelaide - maybe catch up.
Old Sep 20, 2008 | 04:09 PM
TimBucTwo's Avatar
If you have good bulbs and earth, the problem is in the flasher unit. Inside them is a bi-matalic strip that heats up and breaks contact when the flashers are used. They get week and move slow.
Old Sep 20, 2008 | 06:47 PM
Coopz's Avatar
Hmmm.. it flashes at a normal speed, it just takes a few secs to come on. Globes are fine, starting to think its a earthing issue, I'm gonna pull it apart this morning.
Old Sep 21, 2008 | 12:35 AM
Shadow's Avatar
If the other 3 flashers work correctly, it's not the flasher unit, Coopz.
I had a similar problem on a GPZ I was rebuilding - ran another earth wire from the bulb carrier to the bike, problem solved. May just be a little corrosion on the earth/ earth wire for that flasher.
Old Sep 21, 2008 | 06:39 AM
mikekop's Avatar
October 2009 ROTM
I've had the same problem coopz, but after winter storage, suggesting corrode issue. Easy solve for me, just some WD-40 or similar in the button thingie on the bars. Just spray with the small tube attached to the can, stick it in where the lever goes out of the block.
Old Sep 21, 2008 | 09:37 AM
Coopz's Avatar
Ok, thanks, will try it tomorow
edit: Seems to have fixed it, cheers
Old Sep 22, 2008 | 01:41 PM
bigape's Avatar
If earthing is grounding, I agree with the others. The rubber seal around the lens isn't the greatest in the world and will sometimes let moisture into the lens. I have seen rust around the socket base that interferes with proper grounding.
One of mine did the same thing, I just took it apart and took a little sand paper to it.
Old Sep 22, 2008 | 04:32 PM
MarkR's Avatar
earthing& grounding aren't really the same thing, I guess.
grounding refers to a common (-) reference point of a system, IE chassis
where earthingrefers to Mother Earth.
So, our bikes are Grounded and my Beer fridge is Earthed
Old Sep 23, 2008 | 11:04 AM
Shadow's Avatar
Earthed and grounded not the same ?
Hmmmmmm - must be an Oz thing.
Have to Google it
Glad you found it Coopz -
