SC24 1000F with 95Tkm...yes or no
Old Nov 14, 2023 | 03:20 PM
Hawkwind2016's Avatar
95K kms is not high for these engines, so long as it has been serviced even half heartedly.
The cam chains always rattle on these engines, I wouldn't be too concerned.
She looks really straight and original. personally I think you scored yourself a bargain.
Good luck.
Old Nov 14, 2023 | 03:24 PM
marqus's Avatar
First quick and dirty test: only 6-7 bar compression on Cyl 1 with little bit of oil put in plug hole. Carbs not connected and engine totally cold…
I will tear it apart…
Old Nov 14, 2023 | 05:20 PM
Ed Harris's Avatar
Check the valve clearances first
Old Nov 15, 2023 | 11:16 AM
marqus's Avatar
Hi, clearances are in range. I cleaned the carbs in ultrasonic. Totally disassembled. Could start the engine. Runs smoothly.
Checked Cyl2, 10 bar.
since I already bought a gasket set, I will take the head apart. I like to know that I de-carbonated the valves and did the seats.
will come back
thx
Old Nov 17, 2023 | 01:39 AM
dannoxyz's Avatar
Low-compression in #1 may be due to burnt-oil clogging rings due to using dino oil. Be sure to use only full-synthetic moto oil only. My VFR just passed 161K-km this year and runs as good as 1st day I bought it! I owe lots of that to using only full-synthetic its entire life. Many of these engines have gone over 600K-km!
Be sure to do good valve-job while you've got it apart so you won't have to take it apart again for long time! Cut upper & lower angles to make contact seat at narrow end of range. Along with setting valve-clearances at high-end of range. Will give you best sealing that lasts longest. This is for newer model, should find specs for yours.
Most likely it's not mechanical issue, but electronic. Test for spark, probably isn't any. You'll want to measure for power going into ignitor, and into coils. Check out these threads for some ideas on where to start measuring:
https://cbrforum.com/forum/general-t...-coils-162995/
Mike Martin's ST1100 Maintenance Tips - Intermittent Misfire
https://www.1000rr.net/threads/engin.../#post-4335761
https://www.600rr.net/threads/fuse-j...ooting.589644/
Old Nov 17, 2023 | 09:54 AM
@marqus Wow, that's a great looking machine. Enjoy the journey mate.
Old Nov 18, 2023 | 11:35 AM
marqus's Avatar
, Thank both of you. Sorry, I wanted to go on in the other thread. So please check there because I have a new issue :-)
CAFERACER1000F
Rides
Nov 19, 2017 03:53 PM
godoyi1452
Dec 20, 2012 04:53 AM
todem76
CBR1000F For Sale / Found
Oct 7, 2010 08:13 PM
Jeff B
May 13, 2007 01:39 PM
Firefox11
Apr 15, 2005 10:05 AM
