Running issues
Old Jul 25, 2024 | 05:30 AM
Originally Posted by Al1040
If they come off fine, leave well alone. You can get some oil that will help to soften the rubber and recondition it, unfortunately I can't remember the name of it.
Agree@Al1040 if they are pliable at all then you’re gtg.
I believe he is referring to wintergreen oil. Lots of folks report success using this when softening up old rubber bits.
Old Jul 25, 2024 | 07:05 AM
rockpool's Avatar
Originally Posted by Calum-CBR1000F
Yeah thought that mate, Cant say ive worked on carbs before to be honest but im sure i could work it out aha. Guessing i just flip the carbs, open up the float bowls then unscrew each jet and give it a good blast out with some carb cleaner?
you are going to need a set of carb bowl gaskets at least - you can get Chinese ones, they work fine but the probability of all four existing ones surviving is very low. Use one strand from a stainless steel cable to poke the hole in the jet clear - carb cleaner is unlikely to work on its own. The idle jet (small one in the parts diagram) is the troublemaker.
Old Jul 27, 2024 | 04:08 AM
Calum-CBR1000F's Avatar
Ok mate will definitely give that a go. I was going to buy an ultrasonic cleaner to help and a carb cleaning kit. Will there be any other O-rings to replace? I was thinking i could replace any of them i will come across with taking jets out etc for E10 resistant ones. Dont really want to get into totally stripping the carbs down and replacing diaphragm's etc. Just anything in the bottom end of each carb really while im in there. Cheers for the advice mate
Old Jul 27, 2024 | 09:17 AM
You can also pick up the o-rings from here, recommended by one of out senior forum members.
https://litetek.co/Carb_Kit_Honda_CBR1000.html
Old Jul 27, 2024 | 09:42 AM
I've purchased a set from here and can confirm that they are quality products. It did take a while for them to arrive but nothing unusual coming from Asia.
Old Jul 27, 2024 | 01:12 PM
rockpool's Avatar
ebay is the go-to place for chinese rebuild kits - for example https://www.ebay.com/itm/38533149523...3ABFBMrIqX1p5k
the jets are the easiest things to replace - they are brass so no need to be concerned with them. If they look ugly soak them in vinegar overnight.
Old Jul 27, 2024 | 03:14 PM
Cheers mate, I have just decided to buy a full rebuild kit from a company that stocks decent quality ones here in the UK now anyway so i will just replace the lot
Old Aug 2, 2024 | 10:48 AM
walivabuc's Avatar
glicerina per ammorbidire i quattro manicotti
motopsycho87
Sep 27, 2012 09:54 PM
Atrom
F2 Tech
Jun 7, 2011 12:27 PM
hnda900rr1
Apr 22, 2009 11:08 AM
Dennis in NH
Mar 29, 2009 11:53 AM
Cru
Sep 12, 2007 03:26 AM
