Adjusting choke
Old Jun 6, 2011 | 01:04 PM
Atrom's Avatar
Default Adjusting choke
I took off my carbs a week ago and ever since it has been back together my bike will not start with half choke or more...and if it's running and give it half or more choke it dies.. Do I juss need to adjust it? Maybe it's too tight or too loose?
Old Jun 6, 2011 | 06:24 PM
buickid's Avatar
Take the tank and airbox off, you should be able to see the choke mechanism and how it works, and if it needs more slack.
Old Jun 6, 2011 | 10:17 PM
1992 gsx600f's Avatar
Registered Users
definitely inspect it, like he said, but doesn't sound like too out of the ordinary behavior to me anyway
Old Jun 6, 2011 | 10:56 PM
adrenalnjunky's Avatar
if you adjusted the carbs, and the bike is now cranking without choke, then why use the choke?
You would never really wanna turn on the choke on an already running bike.
Old Jun 7, 2011 | 01:18 AM
JesseAwesome's Avatar
Meh, it just richens it a smidge. It won't blow up or anything
Check the free play in the cable, check it's operation, etc etc. You should be able to troubleshoot this in under an hour. That cable generally desont' need lubing, but it will go dry over the course of nearly 20 years. I bet it's never been lubed. Give it a few squirts, work it in there, and then you're ready to ride.
(that's what she said).
Old Jun 7, 2011 | 12:27 PM
Atrom's Avatar
Haha. Thanks, looks like I got some trouble shooting to do.
dgk600f4i
Apr 15, 2011 12:57 PM
mbrown22
Nov 23, 2010 10:37 AM
dalves11
Sep 22, 2010 04:47 PM
dyracuse
Jan 15, 2010 04:58 PM
ThisisMickey
Nov 23, 2006 09:36 PM
