RPMs slipping under power
Old Mar 30, 2009 | 09:03 AM
Rabid's Avatar
Default RPMs slipping under power
Hi guys,
'87 CBR1000F here, 40,000 miles - in second gear (or even third), the transmission seems to "slip" under high power. For example, in second gear at full throttle around 6-7k (right at the powerband), the bike will almost act as if you're engaging the clutch and it will redline at 10.5k. Needless to say it's a very scary thing when it happens.
Any ideas? Do I need clutch plates? Is the procedure for my '87 the same as the guide listed here:
https://cbrforum.com/forum/showthrea...ghlight=clutch
Thanks!
Old Mar 30, 2009 | 09:06 AM
swisherred's Avatar
sounds like plates/discs or springs to me..maybe someone else knows more...
Old Mar 30, 2009 | 09:13 AM
Rabid's Avatar
I'm also thinking it could be dirty clutch fluid. Is it hard to change?
Old Mar 30, 2009 | 09:16 AM
mick's Avatar
the clutch has gone, seeing as it's only slipping in the power band you'll probably be alright just replacing the friction plates, there are 9 of them, the first one that goes in has a different part number than the other 8,so don't muddle them up!! remember to soak them in oil overnight before fitting.
good luck, it's a straight forward job.
Old Mar 30, 2009 | 09:22 AM
Rabid's Avatar
Thanks mick - is the procedure the same as the one listed for the 93-96?
(listed here: https://cbrforum.com/forum/showthrea...ghlight=clutch )
And also, do you have to change the fluid when you change the plates out?
Old Mar 30, 2009 | 10:10 AM
Shadow's Avatar
Change friction plates- they're shot......
I'd replace fluid also
Same procedure as later models
Clutch plates on e-Bay
Old Mar 30, 2009 | 04:57 PM
Rabid's Avatar
Thanks shadow!
Old Mar 30, 2009 | 06:25 PM
Imo000's Avatar
Don't forget to get a new oil filter too.
tqaa48
May 27, 2014 03:19 PM
cjpetrus
Oct 9, 2012 03:16 PM
2001-f41
Aug 29, 2012 06:56 PM
darkyuy
Jun 10, 2009 11:49 PM
cbrocket1000
Feb 5, 2008 08:29 PM
