Rev counter behaving oddly
#21
#23
Guest
Posts: n/a
Musta been a plumbers crack
Think maybe a big **** farmers crack might still be closer .....
#24
#25
When I got home I had a go at adjusting the balancer with the engine warm (had been resting an hour or so). No matter how many times I turned the adjuster, in both directions, I couldn't get the engine to whine. DOES THIS MATTER?
I also thought I'd check the spark plugs. They are all the correct shade of brown but THEY WERE ALL LOOSE. I was able to remove them without a wrench.
Here's a link in the 'How Too' section.https://cbrforum.com/forum/how-tos-8...stment-107818/
Strangely, I had exactly the same spark plug experience the first time I serviced my bike shortly after buying it. I think maybe they can work loose if they haven't been tightened properly? Don't over tighten them though!
Glad your problem seems to be resolved, but you might want to try the balancer adjustment again when cold.
#26
#27
It's started again
I tightened all my spark plugs and the wandering inaccurate rev counter stopped wandering and became accurate.
For 18 miles.
I got on the bike to come home tonight and at idle the engine felt like 1200 rpm but the rev counter showed 1600 - 1800 rpm (after the engine was warm), it read too high in every gear and wandered up and down.
I checked the spark plugs again but they're not loose and the engine sounds as if it's firing on all four.
Guess I'll have to check for shorts, bad connections, etc, but I was wondering, could it be the CDI unit?
Thanks all
For 18 miles.
Thanks all
#28
on
Doubt it's the CDI - I'd say a chafed wire somewhere. I'd start at the harness plugs
at the instrument panel under the nose cowl - I'm thinking one connector is
corroded, loose or something
Some rainy day take the fairings off and start going through the harness from the
clocks on back but I really think the issue is up at the harness connection plugs at
the clocks tho'
the clocks tho'
#29
I was just reading through this thread and seeing what has already been said.
The tach is the electronic type. It is actually counting the number of sparks it sees/time frame. If you have poor plug wires that are arching, the tach may be counting false sparks. Arching can happen more often in wet conditions.
If a plug is not in all the way and making a good ground, an adjacent plug wire may choose to send the spark to a touching wire and to its plug. In a certain time frame the tach would count more sparks then in a non-arching condition and give a high rev count.
The spark signal from the ignition control module goes to the coils and to the tach. If those wires are shorting, false reading will be seen.
