Digital counter problems
Old Jan 22, 2008 | 07:32 AM
DMICHELS's Avatar
Default Digital counter problems
Hi Guys
My friend rides a CBR 954 rr 2002 model but have problems regarding his mileage counter.The counter is not giving him the correct reading.He has road his car and bike the same distance but the bike reading are out with 7 kilomoters less the carscounter.He had set it to miles and back to Kilomoters but still experience the same problem.Is it possible that there are setting to set the counter to kilomters and miles.Can somebody tell me ifanybody had experience the same problem and how to get it fix.
Thanks
Spoilt Brat
Old Jan 22, 2008 | 01:08 PM
demonchild's Avatar
Default RE: Digital counter problems
between the cars inaccuracy and the bikes inaccuracy theres no telling what the correct milage should be on either vehicle.
Old Jan 22, 2008 | 02:20 PM
scattabrain's Avatar
I've experienced this as well. I have an 01 F4i and my buddy has an 03 600RR. Both took the same trip but had different readings. We both figured it was due to error in the speedometer as usually the odometer is driven by the speedometer ( EDIT: in cars anyways).
Old Jan 22, 2008 | 03:24 PM
txsmainevent's Avatar
Has your buddy done any sprocket changes???? You kno like down 1 in the front and a few up in the rear?
Old Jan 22, 2008 | 04:16 PM
Terry954rr's Avatar
ORIGINAL: pimpncbr954s
Thats what I was thinking but that would make it read more than actual
Old Jan 22, 2008 | 06:41 PM
demonchild's Avatar
He could have done the sprocket change that Joey did becuase he wanted to go 193mph. That would make it read less than actual.
Old Jan 22, 2008 | 06:50 PM
ramarjagreb's Avatar
Check that the front tire size is correct on both vehicles, most times the odometer gets it's reading off the front wheels. If the tire size has been changed it could explain the variance as to which one is incorrect. Having worked in a tire shop before, I found this occurred fairly often when people increased or decreased their tire size.
Unless your mate monos his bike everywhere, that could account for it too of course...
[IMG]local://upfiles/22904/A5505E50A32040F5ACB3F2534D50607A.jpg[/IMG]
[IMG]local://upfiles/22904/1FDC5A6DCE6148A9BF65907A6920BB85.gif[/IMG]
Old Jan 22, 2008 | 07:05 PM
letsride's Avatar
Gearing changes will throw it off,you candouble check it if you want with a gps system and see what the difference is between them and see which one is more accurate.
Jonesc962
Oct 28, 2013 11:48 AM
hmm
Jul 2, 2012 06:39 PM
mixerspike
Jul 25, 2009 06:21 AM
seldon929rr
Feb 23, 2009 05:16 PM
clubsammich
Nov 28, 2008 10:52 PM
