regulator issue
Old Oct 6, 2019 | 12:14 PM
fexfonseca's Avatar
Default regulator issue
hello friends, greetings from portugal
i have a problem and i would like some help please
my regulator is damaged and burn the 10A start fuse, i change the regulator and after 3 weeks the regulator show the same problem.
anyone know how to check the problem.
tanks a lot
Old Oct 8, 2019 | 06:34 PM
Red Baron's Avatar
In my electrically challenged experience 2 things come to mind, heat and grounding.
Anything aftermarket blocking or covering the rectifier?
The other one would be inspect or replace the grounding cables.
Old Oct 9, 2019 | 04:58 PM
airforce75's Avatar
Default Regulator
Make sure your charging level is about 13.8 volts. Also check your battery voltage. It should be about 13.4. if the battery is weak it will over work the regulator and result in heat damage. If you have changed gearing and run constant high rpms that won't help either.
Good luck.
Old Oct 10, 2019 | 02:08 AM
fexfonseca's Avatar
wow tank you so much guys.
i´ll check that as soon as possible
cwcbr91
Oct 20, 2020 09:16 AM
rsaari13
Oct 7, 2012 04:49 AM
PurpleKnight
Dec 26, 2010 08:17 AM
kallelsf2
Aug 21, 2007 10:02 PM
jzcbr600
Apr 1, 2007 07:52 PM
