To rebuild or not to rebuild?
Old Sep 5, 2011 | 09:06 PM
bjjrev's Avatar
Default To rebuild or not to rebuild?
Another question from a new guy... I purchased my bike in boxes. The previous owner said that the engine went with the frame and that everything was from one bike. If that's true then the cluster says it has 14,326 miles on it. Also the engine was wrapped in plastic when I pick it up. The valve cover is off and the cam bolts are loose. What would you guys do? Rebuild to be safe? Just trying to plan ahead... I have plenty of work to do already.
Old Sep 5, 2011 | 09:16 PM
onefootedkId's Avatar
I am extremely picky with motors. I've had one of my hawk race motors tear its self apart, metal shavings everywhere. So when it comes to motors, I would do a good looking over and CHECK and Re-CHECK everything. You never know why all that stuff is like that. Its better to be safe then sorry, it would suck if you got all put together and something with the motor was wrong.
Old Sep 5, 2011 | 09:33 PM
Sprock's Avatar
More work :
Get it tightened down and valves in time ....then do a compression test to see if she's
tight or not...hate to say it but they may have been loose for a good reason ....hopefully not
Old Sep 6, 2011 | 05:43 AM
bjjrev's Avatar
I talked to the guy who I bought it from and he said that his intentions were to rebuild it then plans changed so that's why the valve cover was off and can caps loose... Def gonna go with that compression check sprock! Thanks!
Old Sep 6, 2011 | 02:17 PM
Shadow's Avatar
Check the camchain and tensioner while the caps are loose and the tops off.
Old Sep 6, 2011 | 02:37 PM
bjjrev's Avatar
Is there a test I can do to see if they are ok?
Old Sep 6, 2011 | 05:19 PM
kilgoretrout's Avatar
Administrator - Retired
The big question is why he was gonna rebuild it.
Old Sep 10, 2011 | 08:46 PM
bjjrev's Avatar
Well... He said he always rebuke m
Old Sep 10, 2011 | 08:47 PM
bjjrev's Avatar
Sorry... He always rebuilds m
Old Sep 10, 2011 | 08:49 PM
bjjrev's Avatar
Damn cell phone... Hahaha he always rebuilds motors when he gets them just to be Safe... How would I spin the motor fast enough to do a compression check? Should I just go for a top end rebuild?
93etgocart
Jan 8, 2012 03:40 AM
rlfknlorangers
Jul 5, 2008 08:22 PM
BlindinOrange
Jul 2, 2007 05:28 PM
maxxheadroom
Sep 12, 2006 05:13 PM
mrc03rr
Jun 30, 2005 05:38 PM
