rear tire width
Old Mar 9, 2014 | 06:06 PM
chvbob's Avatar
Default rear tire width
Anyone put a 180 width tire on the back? Just wondering if it would fit. Not that much wider.
Old Mar 10, 2014 | 10:06 AM
TimBucTwo's Avatar
What year???
Old Mar 10, 2014 | 10:21 AM
Shadow's Avatar
Sure, I've run a 180 since I bought the bike 9 years ago. It's a Mk2, so for that model which runs a 170 as factory spec the 180 is fine. The 87/88 Mk1 runs, I think a 150.
I'm told the 170 tyre on the mk2 will lean over with less effort, but most guys on here I think run the 180.
Old Mar 10, 2014 | 03:22 PM
Sebastionbear1's Avatar
Yep, I run a 180 on the Mark 2 - and love the handling!
Cheers, SB
Old Mar 10, 2014 | 03:33 PM
chvbob's Avatar
sorry i didn't put the year in. It is a 1991, and it has the 170 on the rear. I have a buy on a set that has the same front, and the 180 rear.
Old Mar 10, 2014 | 04:29 PM
Sprock's Avatar
Got one on mine , expect it to potentially wear a v grove in the plastic chain guard
depending on brand and profile of tire other than that go for it
Old Mar 10, 2014 | 08:42 PM
hurricanematt's Avatar
I run a 170 on the rear of my 94. May go to a 180 next time i dont know. I heard the bigger tire has a tendency to push the front in the corners. I ran a 160 rear on my 88 and could not tell a difference in the handling over the stock 150. So maybe the 180 over the 170 will not be noticeable.
Old Mar 11, 2014 | 09:10 AM
TimBucTwo's Avatar
Yeah, on the '91 the 180 is only 10mm wider. That is just 5mm per side. Many newer bikes run the 120 up front and a 180 in the rear. The 55 vs 60 ratio will give the same tire height as the 170 so no problem there. I switched to the 180 and never went back. There are more choices and better tires in the 120/180 set at better prices.
Mine looked a little tight so I pulled the guard and bent the tab a bit and now have clearance.
Old Mar 18, 2014 | 05:08 PM
cbr_lover's Avatar
I ran a 180/55 on my old 1995 1kf and the 1993 i have recently bought already had one fitted - there is a slight groove worn on the inside of the chainguard - i guess the previous owner didn't think to bend the chain guard tabs!
I have never rode one with a 170 fitted so don't know what it'd be like.
Old Mar 18, 2014 | 06:44 PM
DragonCBR's Avatar
i run a 180 n my 88 with the orginal swingarm it fits, no grooves nor marks on the tire.
motopsycho87
Aug 22, 2012 09:43 PM
kxracer103
May 19, 2007 06:28 PM
95pirate
Apr 4, 2007 01:35 AM
Chrisct713
Sep 2, 2005 02:40 PM
grwilson6
Apr 21, 2005 08:30 PM
