Question-Coolant and Fork Oil for CBR1000F
Old 12-01-2010, 08:10 PM
kilgoretrout's Avatar
Administrator - Retired
Many of the RED anti freeze products today are OAT ( Organic Acid Technology ) - they can not be mixed with the older type glycol based anti freeze.
Yeah, some of them are orange, too. Like that dexcool junk.
I wouldn't recommend mixing any coolant unless you're 100% sure what it is, and it's made for use in aluminum engines. Regular green Peak or Prestone mixed 50/50 with DISTILLED water is what I use in everything.
I have seen purple, red, green, orange. blue. I am sure there is others.
Yep, I've also seen yellow and pink. lol...
Seems stupid as hell to me. It's antifreeze for gawds sake. Do we need every color of the rainbow?
Hmmm... I wonder what would happen if you mixed all the colors together?
Old 12-02-2010, 08:16 AM
hawkwind's Avatar
Originally Posted by hawkwind
As far as I'm concerned, red green........it's just a colour does the same job and is better than nothing! It takes 10 mins to drain the coolant from these bikes.
Originally Posted by Dean0
Be careful - Not true any more !
The result of mixing the two is a horrid mayo like mush making you think the head gasket has gone.
The cure is a very thorough cleaning of the coolant system and re-fill with the correct anti freeze.
Sorry Deano I didn't mean to give the impression I was saying you should mix it
As I also said, 'it takes ten minutes to drain the coolant on this bike', a good flush doesn't take much longer and of corse it needs to be compatible with aluminium, but I think most are these days?
When it comes to topping up, I'd use distilled water(unless you know what's in there already) and then investigate why it needs to be topped up in the first place as it may indicate a more serious problem, like leaks or weak hoses and constant topping up will weaken the mixture.
Old 12-02-2010, 01:44 PM
TimBucTwo's Avatar
AMSOIL makes a biodegradable antifreeze that they say can be mixed. The sealant is the only turn off to me. Not needed so why introduce it to the system.
Check it out---> LINK
It almost sounds like it would make a good mixer in a pinch.
Wakey1races
03-27-2014 04:36 AM
MattSD
07-28-2013 05:12 PM
Bazil Brush
06-30-2013 08:04 AM
tjobowa
05-28-2007 01:16 AM
Quick Reply: Question-Coolant and Fork Oil for CBR1000F
