Question.
Old Aug 27, 2010 | 07:06 PM
bundy26's Avatar
Default Question.
I was riding today, was in 6th gear and when I gave it gas to speed up the revs climbed ,but suddenly the revs went from 6000 to 10000 and back down, kind of felt that clutch was not hooking up right.
Could it be the clutch or is it something else?
Old Aug 27, 2010 | 07:46 PM
Az1kF's Avatar
Sounds like clutch slippage to me. Possible between gears.
Old Aug 27, 2010 | 08:33 PM
davethepom's Avatar
Sounds like the clutch to me. If it was between cogs it probably wouldn't have re-engaged and if it did you'd have heard some bad crunching and would've lurched badly.
If it is the clutch it'll just get worse until you get the ***** and change it.
Old Aug 27, 2010 | 09:52 PM
bundy26's Avatar
That's what I thought, going to order the parts, might as well get the brakes, plugs and chain/sprockets. Thanks.
Old Aug 27, 2010 | 10:10 PM
Sprock's Avatar
Ya sure you don't have "energy conserving" stamped automotive oil in there ????
That will make it do exactly that !!!! ......... ya really have to watch out for the
newer oils labeled that way with what are essentially friction modifiers that make
wet clutches slip like crazy !
Other than that .... if not that is ....... a new clutch is in order
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
