Problem..
Old Aug 20, 2009 | 11:04 PM
Equaliser's Avatar
Exclamation Problem..
Hi guys,
I have an annoying problem with my cbr1000f ('95) Hurricane.
Every now and then during a cold start (with choke), the bike runs for a while then slowly dies. Restarting the bike takes time as it seems to be flooded. Some times when I feel the revs dying, I can push it off the centre stand and jam on the front brakes. This tends to allow the revs to build up again.
Has anyone experienced this before, and if so what did you do?
Old Aug 20, 2009 | 11:20 PM
thrasher572's Avatar
Replace your failing battery and check your charging system
Old Aug 21, 2009 | 07:32 PM
Sprock's Avatar
I moved your post here mate ...
Are you progressively backing off the choke while she warms??
If you leave the choke on as she warms , as she gets warmer and warmer , she will flood revs will drop and she will stop !!
Try , just inching the choke back a tiny bit at a time once the revs start to drop or even before she starts showing any temp on the gauge .....
S'what I do 7/8 , then 5/8, 1/4 done
Old Aug 21, 2009 | 09:12 PM
kilgoretrout's Avatar
Administrator - Retired
I put it on full choke for about 30secs, then turn it off and I'm good to go.
Once in a while it will act a little funny in really cold weather, but 99% of the time it's no problem.
Tell us how you make out with this, EQ..
Old Aug 22, 2009 | 12:02 AM
Equaliser's Avatar
Thanks,
I will try that.
Old Aug 22, 2009 | 07:52 PM
fast1000f's Avatar
i have the same bike as you, full choke for about 15 secs, half choke for the same, than off. works like a charm everytime
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
