Possible gas leak??
Possible gas leak??
The other day I had my 93 model parked in the parking lot on a sunny day about 85 degrees. I happened to be looking at it when I saw one drop of gasoline fall from under the bike, just to the rear of the kickstand. It was really warm with the sun beating down on the bike.
When I got home i stripped all the plastic and raised the gas tank and looked every where, but never found a leak. Is it possible that one of the overflows could have caused a drop to come out due to the excess heat from the sun? Had about a 1/2 tank of gas.
I don't know when the last time you gassed up , but if it was really full the gas might have expanded in the heat of the sun and a little gone down the overflow , I think the overflow is on the same side as the side-stand . Or maybe a little just sloshed over into it?
Anyhow if there's no smell of gas and no more drops I guess it must be OK , just keep an eye on it
Sorry just re-read your original post DUHH! wouldn't be any of that stuff then would it.
