Pod Filter 55mm or ??
Hello to all, thank my you for taking time and veiwing post, I bought a bike 2 weeks back and the pod filters are preety ****ty, Im rejetting my bike and the parts are on their way, Question of the day is on the CBR1000F Carbs should I install a 55mm Pod or a 60mm pod and what kind of modifications am i looking at? Thank you once again for everyones time
EDIT:- Forgot it's a 1991 CBR1000F , If that makes a difference of any sort.
Live Free!!! Ride Hard!
Well, I canceled my order but I'm going to order #125 main and 42 as a pilot jet.. So i am wondering what I should use 55mm or 60mm and if i use 60mm or 55mm what kind of modification of the tubes will i have to do.
Edit:- I just calculated and it shows #135 main jet and #45 Pilot Jet and 2 shims for each needle.
This si what the calulator said
You are riding at an altitude between 400 and 800 Feet
You are riding at a temperature between 75 and 95 degrees (F)
Only 1 Jet Kit needed for all your carbs!!
for Heavy modification
eg. K&N air filter and open aftermarket exhaust.<----- I am using Delkevic 14".. would this be open aftermarket exhaust or would it be light aftermarket exhaust??
This Kit contains: four Main jets size 135 , four Pilot jets size 45 and 2 shims for each Slide Needle.
Live Free Ride Hard
Live Free Ride Hard
Last edited by Aman Lokhandwala; 06-17-2012 at 02:18 PM. Reason: change in numbers
