Paddock Stands
Old 12-18-2014, 07:40 AM
Chippy211's Avatar
Default Paddock Stands
Hi folks,
I have asked my son to get me some paddock stands for Christmas and birthday, only 24 days between them and I want a headstock paddock stand for the front.
Does anyone off you kindly people know what size pin is required for our headstock and can anyone recommend a decent well priced make of paddock stands.
There is no rush due to me being on the rig for Christmas and New Year but he wants to get them before I get home.
Thanks in advance.
Old 12-18-2014, 10:38 AM
CorruptFile's Avatar
June 2013 ROTM
Not sure about the 1kf, but the 600f has a 24mm. Problem is I couldn't find 24mm pins at a decent price. What I did was use a 17mm socket, which had 24mm OD and a 17mm pin. I just pop the socket on the pin and then use the lift. Stability isn't compromised whatsoever.
Old 12-18-2014, 11:36 AM
Mattson's Avatar
Just bent and broke my pin doing this only the socket was 23mm OD. Same for the triumph, seems to be the most common size. Someone with a 1kf will probly verify this shortly.
Getting a new pin done from solid axel. Most stands sold here comes with a fistful of pieces of metal pipes that you put on top of each other to increase the pin diameter. It's pretty stable that way, I just happened to lose the fittings so I tried ghettoing my way around it
Old 12-18-2014, 11:55 AM
June 2013 ROTM
Interesting. I've used it for a while now, lots of cycles and never broke. But now that I've said that...
Old 12-28-2014, 04:59 AM
KenG's Avatar
Senior Member & can cook minute rice in 58sec
i borrowed one with a 22 pin, fitted ok in my 99f1000 to do the fork seals, it was a made up pin of a lathe though, as the fella lent me it, had a F said it was wedged on the front fairing with the standard one. maybe made the difference. took a wee bit of a help to get it up on, but gave me excellent clearance for the forks to be stripped.
CJardine
09-29-2011 01:24 PM
hawkwind
The Hurricane Saloon
14
01-26-2011 01:26 PM
scoobyjacko
03-03-2008 02:39 PM
woot
07-24-2006 10:38 AM
Quick Reply: Paddock Stands
