ongoing unsolved running problem - please help me
Old 05-11-2012, 10:44 PM
EpicLife's Avatar
Registered Users
oo and yes i tried the open gas test
  #92
Old 05-12-2012, 07:12 AM
t85konrad's Avatar
Itblooks like u might have a busted petcock. Is ur off also stopping the gas flow?
  #93
Old 05-12-2012, 12:01 PM
EpicLife's Avatar
Registered Users
i have a brand new petcock, month old .. old one that came with the bike was a leaker .. it flows fine i tryed the flow on RES off of the tank to make sure it wasnt blocked
  #94
Old 05-12-2012, 12:42 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
Is the **** on backwards res is really on and on is res , can you take a pic of it?
Dub
  #95
Old 05-13-2012, 02:01 PM
TimBucTwo's Avatar
My guess at this point is that the fuel lines are not connected correctly. It seams like fuel is weeping in and not flowing freely like it should.
Someone (like Sprock) will have to tell you how to route the lines.
Something still not right.....kinked line, to small filter....something.
If fuel is flowing, maybe the fuel line is hooked to the vent instead of the fuel in port.
  #96
Old 05-13-2012, 05:12 PM
wooferdog's Avatar
I know now he's on gravity feed. When I was having my fuel pump troubles and went gravity to make sure my problem wasn't something other then fuel delivery, I was surprised at the line routing. There was a lot of it. So without seeing how much fuel line is on this bike. I'm beginning to think something is either kinked or might be too close to something warm and causing a vapor lock.
I'll suggest running the lines through its normal course of travel as if it had a pump and maybe slipping a larger inner diameter hose over the bends to prevent kinking and where, as an insulator, near any hot engine bits. That's the best I can come up with. Good luck to you
Maiens
09-08-2013 12:13 PM
citroenexpert1
01-29-2013 11:12 AM
switched
F2 Tech
04-06-2011 12:32 AM
rapidspec
F2 Media
09-03-2010 03:29 PM
JOHNJOHN
03-13-2010 11:04 AM
Quick Reply: ongoing unsolved running problem - please help me
