Oil preassure gauge on CBR
Old Jul 25, 2006 | 07:28 AM
R1000's Avatar
Default Oil preassure gauge on CBR
Anyone using an oil preassure gauge on the CBR? I think it would be a nice feature to have and to be able to monitor the oil preassure from time to time. I don't want to wreck this great engine which deserves good care. A preassure gauge may say a lot about the condition of the engine and some about the oil condition. Got fresh gauge-inspiration from Captain's farkle thread
Old Jul 27, 2006 | 05:29 PM
R1000's Avatar
Default RE: Oil preassure gauge on CBR
Oil pressure gauge installed. I located it on the right hand small triangular fairing between the gas tank and the top fairing. Readings are 20 PSI (1.5 Bar) hot engine on idle and 90 PSI (6,5 Bar) from about 4500 rpm.
[IMG]local://upfiles/4562/158714C9A55E4D88AC38E91517480266.jpg[/IMG]
Old Jul 27, 2006 | 06:15 PM
TimBucTwo's Avatar
ORIGINAL: R1000
I agree. Where did you tap into?
Old Jul 27, 2006 | 06:17 PM
Stray Cat's Avatar
Very cool [sm=goodidea.gif]
Where did you mount the sending unit?
BTW Glad I could be an inspiration
Old Jul 27, 2006 | 06:45 PM
R1000's Avatar
ORIGINAL: Captain Obvious
Yes i'ts your fault that I have to work this evening with the bike but I'm real happy to be able to monitor the condition of the engine much better than before. The oil pressure lamps normally goes on only a few seconds before the conrods escapes thrue the engine case...I installed the sensor(s) on a T-joint at the original oil pressure sensor position, on the lower engine case under the right fairing. The new sensor to gauge was somewhat large, but using a T-joint instead of the included Y-joing solved the problem and I still have the idiot-light working as before. Sorry I didn't took a picture when the fairing was off. I pointed the old sensor/switch at 2 'o clock and the new cylindrical analogue sensor at 8 'o clock position. That was the only way for me to clear the side fairing from touching the new bulky sensor.
[IMG]local://upfiles/4562/7BD9744846434CAFB71B89A935C73728.jpg[/IMG]
Old Jul 27, 2006 | 10:57 PM
grwilson6's Avatar
nice work i might have to look into that too.
Old Jul 28, 2006 | 12:03 AM
Illushun's Avatar
I gotta tell you all something right now! With the swing arm mod, the clock, temp guage pod mod, now the oil guage mod, running tests on the tires....
I just can't keep up with all the projects that get posted and then I end up going out in the garage after everyone goes to bed... Then my wifes comes out there and asks me, "do you know what time it is?" I say no, she says look out the door. I go to the garage door open it up and it's daylight. I remember going in there around 10:00 p.m. the night before.[sm=sleeping.gif]. Hahahahaaa
sorry wasn't trying to highjack the thread. I just love all the projects. Keep it up.
Old Jul 28, 2006 | 03:03 PM
R1000's Avatar
I gave the pressure gauge some maintenance today to make it bike proven. It is a cheap ($ 20) unrugged gauge for cars, so I pryed off the bezel and sealed it with silicone under the bezel. Not fun if it will rain inside the gauge after the first wash. There was also a disturbing misreading, the needle didn't fully moved up to zero when the ignition was turned on, about 8 PSI was missing, i.e. it showed minus 8 PSI. I just took the needle away and relocated it at zero whit powered gauge but engine off.
Bad news - I got a signed cerificate from a policeman this morning that the CBR is capable of a speed which they dont see very often [X(], damn. There was no traffic around, so I was at least not handcuffed [&:]
Old Jul 28, 2006 | 03:16 PM
Stray Cat's Avatar
ORIGINAL: R1000
Ah yes.. we call them "performance awards"
I think it's a CBR thing, because after many years of awardless riding on other bikes (yes just as fast and powerful) I avoided the awards until one month into CBR ownership.
Glad to hear you avoided the cuffs though. That would have sucked.
Old Jul 28, 2006 | 03:28 PM
R1000's Avatar
Performace award, what an encouraging definition I couldn't put it in a frame on wall though, got another recently and need to keep a low profile on this one for a while...It's certainly a CBR thing.
R Dub
May 8, 2011 12:09 PM
Ace_f4i
Jul 2, 2010 07:21 PM
TK954RR
May 30, 2007 04:19 AM
Armstrong
Jun 8, 2006 08:31 PM
