New camchain tensioner
Old Sep 20, 2009 | 09:58 AM
  #61
kilgoretrout's Avatar
Administrator - Retired
Sounds good, shadow. Thanks for the update. It reminds me to give my bike a good once-over.... maybe a carb balance and balancer shaft check...
Old Sep 20, 2009 | 05:09 PM
  #62
TimBucTwo's Avatar
Originally Posted by Shadow
I've just spoken to a mate of mine who has HUGE experience - he says - you should balance the carbs every time you remove them from the bike. He says the bike is "fighting itself" at low revs, and this will cause the chains to "whip
I agree 100%. You get the Slinky effect of things pushing and pulling. The balancers and flywheels with their mass are spinning at a set rate but the crank,rods and pistons are jerking the chain.
Old Sep 27, 2009 | 06:32 PM
  #63
Trips's Avatar
Chit that was lucky ! ... ok maybe silly question , but I gotta ask ...did you get it out before you ran her ?
Nope actually was 2k from home when the nut departed so I just rode it home.
I had presumed the nut had dropped into the sump as I figured if it had gone into somewhere it shouldn't have it would have seized the engine.
Old Sep 30, 2009 | 08:04 PM
  #64
Sprock's Avatar
I've just spoken to a mate of mine who has HUGE experience - he says - you should balance the carbs every time you remove them from the bike. He says the bike is "fighting itself" at low revs, and this will cause the chains to "whip". Above 1400RPM NO noise, he says because there's more vacuum, and the higher revs seem to make the engine "smooth out" and therefore no chain rattle.
I'll be borrowing a carb balancing unit from this same mate, and I'll keep you up dated.
Until it's done, I'll keep the idle up a bit..........................
Thanks again, much appreciated.
Yeah Pete .......just looking back in time in this thread
Individual carb tuning may be required Snotter
used a Gunson Colortune for precise individaul
carb tuning
Snotter had a post in here confirming quite a bit of what you found out
https://cbrforum.com/forum/showthrea...ight=tensioner
What can I say ........checking waaaaayy back in here is intriguing
I love the history the bike and all the expertise rendered current
and past
Old Oct 1, 2009 | 07:47 AM
  #65
Shadow's Avatar
Nice one Sprockie ! Thanks
Old Oct 2, 2009 | 02:46 AM
  #66
Naga_Thai's Avatar
FYI - here is my experience in syncing the carbs...
Full report here with video..
https://cbrforum.com/forum/how-mechanical-40/how-carb-sync-balance-many-pictures-80614/
WHAT DID THIS MEAN & ACHIEVE?
1. The bike was more than 2 times (200%)outside the limits @ 65,000km.
2. The guages got within the limits @ 62%
3. The CarbTune Pro was easier to use, got better calibration and got within the limits @ 25%
4. Before the Sync I did not notice any degredation in bike performance.
After the Sync I did not "hear" any differance at idle (this surprised me).
After Sync there was a remarkable improvement in low speed torque/smoothness (well worth all my effort).
There was a slight lowering of normal bike temprature (cylinders working together / not fighting with each other).
There was no noticable differance in top speed/power (although I tested to top speed I could not tell any difference - which Im not surprised of.)
Watch a movie here ....
CARB SYNC BALANCE - HOW TO -
http://www.youtube.com/watch?v=GhMZ_n3EsSg
http://tinyurl.com/6qgfnv
Old Oct 2, 2009 | 08:51 AM
  #67
hawkwind's Avatar
So the Gunson colour-tune is more accurate than a normal carb-balancer?
So would the 10mm or 12mm be needed?
The colour-tune would eliminate the need for a carb-balancer or would you need both?
Old Oct 2, 2009 | 02:51 PM
  #68
Sprock's Avatar
Have not done it .........YET Steve.........but the way I read it is they don't necessarily
replace each other.......they are used in a complimentary fashion to achieve the ultimate
"smoother than a baby's **** idle".......so that non tensioned oil drive chain
don't be whipping about. I'd say you'd probably do fine just with the VAC Gauge
setup to balance (sync) the carbs the Gunson.......refines (tweaks) it that bit more
I'd use the Gunson before finishing off with the CarbTune
12mm threads is what our plugs have I believe
There's also Morgan Products to reference for both items
Old Oct 11, 2009 | 10:08 AM
  #69
Shadow's Avatar
Last update on the primary rattle................
I used a set of analogue gauges to reset the carbs - what a pain in the azz !!!!!!!!!!!
Carbs were all over the place, but since I did the adjustment the rattle is down quite a bit and is rideable (at least for a while) - hope that's not famous last words
The idle is def not smooth though - must be some muck somewhere in the idler jetting - revs fine and smooth above 1400 revs.
I'll have to pay for a decent set of carb balancers soon - I think the Z1300 will be a real pig to set with an analogue setup.
So, balancing the carbs def does improve the "death rattle"
Now I just have to figure out a solution to the chain tensioner problem, and we'll be away to the woods !
Nobody I spoke to (technical mob) have ever heard of high temperature cable ties though.
I think I'm going to test it myself with the bike well hot, and I'll get a reading on a temp probe...................stay tuned - I WILL beat this thing !!!!!!!!!!!!!
Old Oct 14, 2009 | 02:43 AM
  #70
hawkwind's Avatar
Mayge something like this would be better?
