Losing clutch fluid from Clutch Slave Cylinder ( I think )
Old Sep 20, 2012 | 06:23 AM
Bordo's Avatar
Default Losing clutch fluid from Clutch Slave Cylinder ( I think )
Guys,
As the title suggests I'm losing fluid from my clutch system. Its not leaking from the banjo bolt on the master cylinder so I'm assuming its from the other end inside the slave cylinder. I will pull the slave cylinder and see what's going on in there. Has anyone else had any issues here ? I'm sure its just a matter of replacing oil seals etc. I just wanted to make sure before I went ahead and ordered the parts. Cheers.
Old Sep 20, 2012 | 08:46 AM
Sprock's Avatar
Yup Bordo - seal is weeping on the slave
had it happen on two of three bikes so far
Simple seal kit will fix it
if you put your finger at the lowest point of
the sprocket cover you should get the the
fluid residue mixed with chain oil there as the
clutch fluid weeps down the inside of the
sprocket cover
Old Sep 20, 2012 | 05:38 PM
Bordo's Avatar
Thanks Sprock. I just ordered the kit. Is it a reasonably easy job to replace these parts ? I take it I will have to let all the old fluid out to rebuild the slave ? Sorry if these questions are dumb.....lol. I havent had to rebuild one as yet. Cheers.
Old Sep 20, 2012 | 07:34 PM
Sprock's Avatar
easy to do Bordo - biggest pain is bleeding the damn line out later
I took the opportunity to do the master at the same time each time
--- gave everything a thorough cleaning of all that orange oxidized fluid
Old Sep 21, 2012 | 07:33 PM
Bordo's Avatar
Yep sounds like a plan mate. I don't suppose you'd have a How To on it ??? I ordered the master cylinder kit as well so I'll just go all the way, dump the fluid and rebuild the whole system. Its only a very small leak but a leak none the less so I'll sort it very quickly.
Bordo
How To's
Dec 16, 2017 08:10 PM
stempy
Jun 7, 2013 11:42 PM
FRM
Nov 2, 2009 10:21 AM
egf4998
Mar 31, 2008 05:42 PM
jaboyak
Jan 28, 2007 01:43 AM
