Clutch losing grip at high RPM?
RE: Clutch losing grip at high RPM?
ORIGINAL: woot
cheapest potential fix is to loosen the clutch cable a little bit... if it is too tight then the clutch will slip.
Good luck!
Sometimes, if you're in a pinch, you can switch the friction plates. Like take the two inner ones and switch em with the two outer ones.
The cable adjustment works, but, like above, may only be a temporary fix. Someone else said others ideas that are great too.
Bordo
09-21-2012 07:33 PM
happy_charly
06-28-2010 08:20 PM
