Help fastwith alternator
Old Jul 17, 2006 | 12:05 PM
cbrmario's Avatar
Default Help fastwith alternator
Hello all,
I figured out that the alternator is not charging. I tried to remove it but it is hung up on something. Does anyone know how to remove the alternator?
Thank you for the advice in advance
Old Jul 17, 2006 | 09:11 PM
hronnes's Avatar
Default RE: Help fastwith alternator
The alternator cover is fastend with 3 bolts from the left hand side. Then you can pull the cover straith out.
Have you measured the charging output?
Old Jul 18, 2006 | 05:01 PM
cbrmario's Avatar
Oh, the cover comes out and not the WHOLE thing? I took out, or tried to, pull the whole piece. It seems to be hung up on something. I will test the output tonight. It should come out in AC, right?
I did test the bike at the battery with the bike running and got a reading of 11.75 V. As the RPM increased, it would go lower by a hundreth or so. I will test it before the rec/reg. If there is a good reading, it has to be a bad reg/rec.
Does this sound correct? I am used to working on suzukis but some problems are common to all machines with similar systems.
I will let you know tomorrow what the readings are. Any advice is appreciated.
Thank You hronnes
Old Jul 19, 2006 | 08:02 AM
Trips's Avatar
I have uploaded a fault finding guide.
http://members.iinet.net.au/~cbr/fault_finding.pdf
Old Jul 19, 2006 | 11:50 AM
cbrmario's Avatar
Wow, nice guide.
I figured it is the regulator/rectifier. I get a low reading to the battery but a good AC reading from the alternator.
Where do I get a good regulator?
Old Jul 20, 2006 | 02:29 PM
cbrmario's Avatar
I have good AC from the alternator. The rectifier is cooked, getting nothing from it. It happened when I was sitting in traffic for about 5 min, not moving. The back of it had some bluing going on.
I found one that is aftermarket for $100. A local dealer was selling it. It is 25% bigger and being made of aluminum, it has cooling fins. It looks better and the bike is charging again!!!! He has more in stock if anyone needs, I will help get it to you, I know how hard it was to find one for myself.
Thank God
Old Jul 21, 2006 | 02:58 AM
malbojah's Avatar
You might want to look into Tripps regualtor cooling setup. I cooked my second one in two months because it overheated.
Old Jul 21, 2006 | 05:09 AM
Trips's Avatar
Its here if anyone is interested.
https://cbrforum.com/m_26983/tm.htm
hmm
Aug 28, 2013 07:21 AM
marcsabb@hotmail.com
Nov 23, 2007 10:03 PM
SILVERBIRD
Oct 7, 2007 11:08 AM
onugreen
Oct 2, 2007 09:25 PM
