got a major problem
Old Jan 22, 2014 | 01:16 AM
yorkiejeff's Avatar
Default got a major problem
guys got a huuuuge prob with my 1000f streetfighter. she runs fine, when she starts, but she just will not start. turns over fine, nice and fast but she will just not fire. she will only fire up if i either run the battery charger at the same time or bump start her.it's a brand new battery as well. took her out for a ride not long ago( once i had got the bugger started). rode for an hour and got home. went inside to dump my helmet and when i got out she wouldn't start. pushed her round to the back of the house and just for giggles tried her. fired up no problem then while i was putting her away i stalled her and she wouldn't start again. begining the think maybe the brain has gone, if it has then it's the breakers for her.
any ideas?
jeff
Old Jan 22, 2014 | 04:53 AM
PossibleOne's Avatar
Welcome Crew Technician
Just start checking the power going to the ecm. Id check continuity, then do a volt check. If all that checks out I would start looking elsewhere, possibly the fuel system, rusty tank? fuel filter, etc and work your way up to your cylinders. Cheers.
-Poss
Old Jan 22, 2014 | 05:30 AM
yorkiejeff's Avatar
done continuity and volt check. its just very odd that its an intermitant problem. like i said, once the bike is running she pulls like a train, have seen 150, without the fairing. been doing my head n for the past year.
Old Jan 22, 2014 | 06:43 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Possible corrosion in some electrical connector. I'd suggest getting some contact cleaner, pull apart any connections related to the bike starting/running and spray some contact cleaner in each one. Also, while you're tracing down those plugs check to see that all ground connections to the frame are tight.
Old Jan 22, 2014 | 09:26 AM
CorruptFile's Avatar
June 2013 ROTM
I had a similar thing happen when my r/r was going. Hot - it wouldn't want to start. After it cooled down a bit, it would fire up. Replacing the r/r fixed it.
Old Jan 22, 2014 | 10:31 AM
Sprock's Avatar
Dicky sidestand switch ?
Old Jan 22, 2014 | 03:25 PM
Yea, Id def be checkiing the components that have the power to kill the bike. Kill switch, wiring. Im not sure about the sensors on these bikes but the things on mine like the BAS and etc. Check any of those. It almost certainly is a wire rubbing or something electrical, it just stinks of it.
-Poss
Old Jan 22, 2014 | 05:46 PM
Sprock's Avatar
Not too many sensors on a Hurricane thankfully they're pretty much
Old Jan 22, 2014 | 06:25 PM
Figured as much . Thats sweet though, I want to find an older one without any of the electrical woes!
Terry Fox
May 14, 2012 11:53 PM
stoneytony
Oct 17, 2010 08:39 PM
jwoody8
Feb 19, 2009 10:53 PM
zoniebutt
Mar 15, 2008 11:18 PM
silver600
Nov 8, 2007 06:48 PM
