fuel pump not working
Old Mar 3, 2013 | 09:26 PM
akiyama640's Avatar
Default fuel pump not working
I have a 88 hurricane fuel pump stopped. got used one from ebay. that did not fix the problem. not getting power to pump,need help finding relay,any help would be great.
Old Mar 3, 2013 | 10:31 PM
Sprock's Avatar
Best bet - ditch the pump altogether and gravity feed direct to the carbs
Old Mar 4, 2013 | 12:32 AM
wooferdog's Avatar
There is a cure for your woes.
Try my solution.
Old Mar 4, 2013 | 04:09 AM
Sebastionbear1's Avatar
Try my solution.
And just what would your solution be Woof? - I canna see a link!
Cheeers, SB
Old Mar 4, 2013 | 04:40 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Cheeers, SB
I'm almost certain that Woofs solution would involve drinking more beer, and not actually worrying too much about a fuel pump.
My bike worked OK without a fuel pump didn't it?
Only real problem with running without the pump was you and I drinking way too much Gin. But I'm not entirely sure that was a fuel pump related issue.
Old Mar 4, 2013 | 05:54 AM
I don't drink too much............I drink juuuuuuuust the right amount!
Your bike TK, worked just fine sans fuel pump.
Chers, SB
Old Mar 4, 2013 | 03:11 PM
wooferdog's Avatar
https://cbrforum.com/forum/cbr-1000f...mp-fix-120780/
That's how I fixed my pump.
Sorry it took me a bit to find the thread
Hook up a curcuit tester to your pump leads off the main harness then hit the starter button. You won't see current to the pump just by turning the key on. Pump won't be energized unless starting or running.
If you find out that you are getting current to your pump, then the problem will most likely be the contact points under the the black cap on the end of the pump
Then go to the above link
Old Mar 4, 2013 | 09:48 PM
Sprock's Avatar
Then ditch the fuel pump & proceed with your by pass plans
Old Mar 4, 2013 | 09:59 PM
That's a bit like how to cook a Galah (a type of Aussie Parrot).
Put a rock in the saucepan with the galah, when the rock is soft, throw the galah out and eat the rock!
But to get back on topic, Kiwi TK's '87 worked famously without the fuel pump, just gravity fed, and it did not miss a beat on the 1500km I did on it.
Cheers, SB
Old Mar 4, 2013 | 10:07 PM
Sprock's Avatar
A Parrot eh Seb - very good.
95frankenF3
Mar 20, 2014 12:05 AM
95frankenF3
Apr 29, 2012 11:12 AM
miksane
Aug 16, 2010 02:18 PM
rubenv
May 24, 2010 03:51 PM
GQuinones84
Feb 6, 2009 02:03 AM
