fuel pump..help
fuel pump..help
need advise .. i was working on fixing a seal leak in the petrol on/off ..fix that ..then i had to fix a another seal from tank to petrol on/off ..both parts are not leaking anymore..except now.. the petrol pump just keeps going like crazy..never stops..is this the relay switch? i've checked its getting in petrol and out but the pump never stops..just buzzes at high speed..the bike started but not sure for how long..
Mine doesn't have a pump so I can't be much help. All I can come up with is that, if it was working fine before, then maybe something has been re-connected wrong or there's a dodgy join somewhere.
If you can isolate the relay then you can bodge up some feed and switch wires to it in order to test it.
Sorry, that's all I can come up with mate.
yeah relay should fry off... left the bike for an hour and went and bought relay and tried her again and all was well, withought needing to change the relay.. i guess it needed time for fuel to fill the hoses completely and get the pump full and no air and she started behaving again. the good news is i think by fixing the the seeping leaks from the petcock the bike is running better.. not stuttering when crawling prolly less air in the mix maybe?
"So is a CBR a dirt bike, I've never heard of them?"
Mind you it only takes me about two minutes to walk to work so I guess that's the upside.
Guest
Posts: n/a
It always worries me when stuff don't work , then later it does without doing chit to it creeps me out !!!!
If I were you I would whack another post up asking how to remove the bastard altogether.... As has been mentioned , they can run fine without them !... Someone here will have done it for sure ...
good luck mate ...
good luck mate ...
good luck mate ...
good luck mate ...
I know what you mean about unresolved causes .. i hate them too..i think in this case it was simply making sure the hoses and pump where filled with petrol..like with a pool pump principle i guess..
hey check out my art work
Kopi Ko
10-01-2019 08:29 AM
