Front Suspension Questions
Old Jul 19, 2008 | 04:38 PM
tallenuf's Avatar
Default Front Suspension Questions
When chagning oil in the forks is it fine to just add the volume given in the manual or must one measure the 172mm?
Also what are your thoughts on going to a little higher weight oil to increase the compression and rebound rates on the forks?
I don't really want to mess with new springs now.
Thanks.
Old Jul 20, 2008 | 04:10 AM
Honda_Hurricane's Avatar
Default RE: Front Suspension Questions
Look at this post
https://cbrforum.com/m_609498/mpage_.../tm.htm#609498
Old Jul 20, 2008 | 11:28 AM
Shadow's Avatar
+1 (at least I can post that ![:@][:@])
Old Jul 20, 2008 | 09:35 PM
tallenuf's Avatar
Did some searching in the forum and found some very good info from Dad on suspension. He made a longer spacer for the front springs, about 5/8" longer, in order to obtain the proper free and static sag measurements. He also went with heaver weight oil and filled the legs higher to reduce the air gap. All sounds good. He said he was 205 at the time and these changes worked well for him rather than new higher rate springs (though new springs would likely have been better yet). I'm 245, do you think a spacer 3/4" longer will result in the proper sag settings for me? That's a little longer than the spacer he made and I'm a little heavier.
Dodgehemi7
Jun 17, 2011 01:23 PM
philthethrillohio
Apr 15, 2009 10:38 PM
Dan607
Oct 22, 2008 12:08 AM
WillRR
Jun 16, 2007 11:15 PM
onblur
Sep 14, 2006 11:22 PM
