freaking me out
Old Jul 3, 2015 | 06:42 AM
cbrpaul's Avatar
Default freaking me out
cbr1000fl
50000mi
perfect condition
garaged
new fuel
regularly ridden each week to 2 weeks depending on time availability
the issue
last week starting on the button /running perfect
this weeks first start= a little difficult
idle ok
trying running at higher rpm than idle=> rough/ missing( no backfire )
its as if a plug had fouled ( but idle perfect ) or starvation ( but idle perfect )
fuel tap on
fuel new
3/4 full
battery well charged
have an in line yam paper fuel filter to avoid bits bunging up the jets
what to look for 1st and 2nd?
regs cbppaul
Old Jul 3, 2015 | 09:50 AM
TimBucTwo's Avatar
I wonder if the bowls have a water mixture in them. I'd try and drain them first thing.
https://www.youtube.com/watch?v=Wrb4pl03xCg
Old Jul 5, 2015 | 10:54 AM
cbrpaul's Avatar
found the problem
plug nr 3 had failed
now runs correctly
why the plug failed when at standstill is one of the wonders of the universe
cbrpaul
Old Jul 5, 2015 | 03:20 PM
KenG's Avatar
Senior Member & can cook minute rice in 58sec
fire a bit of av-gas through it, it'l either kill it or cure it. wheeeeeeelie!
Old Jul 5, 2015 | 06:05 PM
cb2cbr's Avatar
Don't recommend AV-Gas. Whats out there now is 100LL, That's 100 octane, blue in color and stupid expensive. AV-Gas octane rating is calculated differently that auto gas for one thing, the other is it will likely trash rubber parts in your fuel system.
It's rare that a plug fails but it does happen. While it may idle fine it can loose it's fire under load. I had very good service with NGK iridium.
tomzilla808
Feb 23, 2015 10:46 PM
super60daytona
Nov 7, 2010 11:23 AM
maineiack
Jan 31, 2010 05:41 PM
CBRriderNevada
The Hurricane Saloon
18
Apr 27, 2009 10:02 PM
