Fan Dies
Old 09-24-2010, 07:08 AM
rwl1955's Avatar
Angry Fan Dies
The fan on my 1987 1000 doesn`t come on anymore. Any suggestions? I thought I finally had the bike running great.
Old 09-24-2010, 07:47 AM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Disconnect the fan, run two wires from the battery to the fan. If the fan works then it is the sensour, wires, fuse, or connections.
If you have a muliti meter you can chase the 12v. to see if your fan is getting 12v to run
Old 09-24-2010, 03:53 PM
davethepom's Avatar
+1 exactly! If no multi meter, just bodge up any low wattage 12volt bulb with two bits of wire and attach them to the existing fan connections as well. Then run her until the fan should come on and keep an eye on the bulb. If it lights up and the fan doesn't then the fan's stuffed.
Old 09-24-2010, 08:24 PM
Sprock's Avatar
OR
with the ignition on pull the wire off the rad fan switch and ground it to the frame
if the fan comes on it's the switch if not the fan motor
Old 09-25-2010, 02:16 AM
Ilson Lad's Avatar
Originally Posted by Sprock
OR
Thats exactly whats wrong with mine-needs a new rad switch! Luckily winter is around the corner
Old 09-25-2010, 11:53 AM
Sprock's Avatar
Just put a manual 12v switch up on your fairing and use it to switch it on and off
Only really needed going slow in traffic ( or following Kilgoretrout) anyway
Old 09-25-2010, 12:17 PM
Ilson Lad's Avatar
Old 09-25-2010, 06:24 PM
kilgoretrout's Avatar
Administrator - Retired
That's what usually seems to happen. A manual switch is usually the preferred fix, too.
Gawd, still at it, eh? And you wondered why I made the video. lol....
Old 09-25-2010, 10:39 PM
Sprock's Avatar
Yup just seeing if yu wuz still awake and yu said i was being too nice lately
Old 10-03-2010, 02:29 AM
bluebeard's Avatar
The plus side of the manual switch is that you have cooling when tuning. Even with an auto switch the manual comes in handy. I made a small mount that comes out under the left fairing insert & sits neatly out of sight & out of the weather. No holes in the plastic.
Killerdimpler
07-08-2013 10:54 PM
94302
05-24-2012 09:02 AM
Cooke
03-03-2012 09:29 PM
Michael S
04-16-2009 08:39 PM
Quick Reply: Fan Dies
