engine knocking??
Old Aug 28, 2008 | 06:33 PM
Kc31019's Avatar
Default engine knocking??
Recently noticed that my '88 hurricane has has some strange engine knocking after a carb clean. I've check the oil and perfect level. It makes a clank and what sounds like metal to metal scrapes. Any idea's what it could be? i bought it with about 9k miles and it just hit the 16k mark...im about 100 miles over it as of today. Before the carbs were cleaned i forgot to mention it was reving at 1000 rpms now its at the 1.5 mark...could it possible be that or maybe its lighter oil then i should be putting in it, ive been changing the oil every 1,500 -2,000 miles with HP4 Honda Genuine Oil.
i would love to hear some feed back. Thank you for you time.
Old Aug 28, 2008 | 07:33 PM
weekendrider's Avatar
Default RE: engine knocking??
Is the noise there when it is hot and loudest at 1500 to 2500 rpm on first start cold.
Old Aug 28, 2008 | 09:10 PM
Kc31019's Avatar
just checked it...its pretty loud at the 1.9-2 spot.when cold, from what i remember being warm..it doesnt do it above that, just when im example stoped at a stop light. The grinding kinda gets comes and goes...about every 4-7 secs it will grind when cold.
Old Aug 28, 2008 | 10:02 PM
Shadow's Avatar
Replace your camchain and tensioner. Mine did the same thing after an oil change.
Old Aug 29, 2008 | 10:04 AM
Kc31019's Avatar
realized that last night it was doing it when it was pretty warmed up.
Old Aug 29, 2008 | 10:41 AM
DRam's Avatar
Very Honorable Most Senior Member :)
Sounds like Shadow has the answer. I replaced just the tensioner and the noise returned in about 1500 miles. Do a searchfor CCT, you'll find all kinds of advice. It's a common problem.
Old Aug 29, 2008 | 12:07 PM
GILL's Avatar
Gotta love the CCt and CC.....grrrrrrrrr. RPM's should be at around 1200 at idle. I'd bump it up a bit so you dont hear the rattle though. Balancer is okay? Dont forget the oil chain and the alternator chain too, they can be noisy too at idle. Mine is! I'd run a thicker oil in the Summer like a 20w50 oppose to a 10w40 IMO.
Old Aug 29, 2008 | 12:08 PM
GILL's Avatar
Hey Shadow, Im going to love the gear drivin cams....hehehe
Old Aug 29, 2008 | 12:46 PM
Shadow's Avatar
The CBR750F had gear driven cams - they went the way of the Dodo, too...he he he
Old Aug 30, 2008 | 12:41 PM
DRam's Avatar
ORIGINAL: DRam
Hmmmm. DRam here. Take a look at my post belowabout strange noises. Maybe . . .
Jaybyrd
Jul 11, 2010 09:44 PM
wheeler6747
Mar 24, 2008 11:28 AM
97CBR900RR
Dec 12, 2007 12:04 PM
Ueafa
May 29, 2007 11:45 PM
four.six
Nov 27, 2006 05:42 PM
