ebay lights.............
Old Mar 29, 2006 | 02:32 AM
crucialfate's Avatar
Default ebay lights.............
http://cgi.ebay.com/ebaymotors/BLUE-...43648556QQrdZ1
possible?
Old Mar 29, 2006 | 03:10 AM
whammy's Avatar
Default RE: ebay lights.............
crap. "HID simulation" and "Xenon technology"
Better try Philips Blue Vision or Osram Silver.
Old Mar 29, 2006 | 05:28 AM
simochell's Avatar
I use PIAA XTREME WHITE PLUS.
H4 draws 60/55W provides135/125W[sm=smiley16.gif]AWESOME!!
Old Mar 29, 2006 | 10:43 AM
geoffv's Avatar
I've got a 90' and I've had no luck finding a white/xenon light for it. I can't remember the bulb type, but I know it's not a common one, the only bulb that works is a stanley.
Old Mar 29, 2006 | 11:03 AM
simochell's Avatar
It`s just a standard H4 isn`t it?
Thats what I`ve got anyway!
Pretty standard dual filament bulbs,unless you use different ones in the U.S.?[sm=americanasmiley.gif]
Try PIAA online,thats where I found em!
Good luck[sm=signs003.gif]
Old Mar 29, 2006 | 03:09 PM
slowpoke's Avatar
ORIGINAL: simochell
Not in the US. The 45/45 H4 bulbs are special that only come from Honda. The two side tabs are in a different location from regular H4 bulbs. To fit regular H4 bulbs, the side tabs have to cut off to fit into the socket. And I read that the blue tint on those Xenon bulbs cut down the light significantly. I use 55/60 H4 Candlepower bulbs with the side tabs cut off on my 1990.
Old Mar 29, 2006 | 05:25 PM
simochell's Avatar
The blue tint doesn`t affect the light output,as it`s only on the tip.They`re usually coated white aren`t they?I found the blue hew a bonus as the light is emitted with a crisper look and gives a much better contrast to oncoming objects,so you don`t get that blending in look!
Plus they`re twice as bright,which helps!!
Old Mar 30, 2006 | 09:59 AM
geoffv's Avatar
slowpoke, so that works huh? I was thinking about doing that. Is the bulb secure in there and doesn't shake around. I was thinking about getting some Osram Slyvania Silverstar ones.
Old Mar 30, 2006 | 03:37 PM
slowpoke's Avatar
ORIGINAL: geoffv
Actually I bought some adaptor rings. The thin adaptor ring has tabs in the correct location for the Honda socket. You place the ring around the new bulb, and bend the side tabs from the new bulb around the ring. Voile. Now you have a new bulb with Honda-type tabs. Except the spring clip holding the bulb in the socket is so freakin' strong, you don't need the adaptor. Just cut off the side tabs on the new bulb (leave the top centering tab) and the spring clip will hold it in the socket forever.
duzzer1
Sep 8, 2013 06:36 AM
xankriz
Apr 2, 2012 03:02 PM
Dragondima
Dec 19, 2010 08:00 PM
mario_r34
Jun 5, 2010 12:50 AM
deerslider
Aug 24, 2009 08:23 PM
