Dumb question: How do you change the coolant?
Old Sep 22, 2007 | 01:56 AM
Coopz's Avatar
Default Dumb question: How do you change the coolant?
Its easy to get at and top up, but where is the cap/plug that drains it? Spent 20m looking for it on the radiator. (without stripping all the fairing off)
Old Sep 22, 2007 | 02:31 AM
R1000's Avatar
Default RE: Dumb question: How do you change the coolant?
Removing the side panels only take a fewminutes so you willget access to thelarge water hose. This is better than flushing through a small drain plug (if there is such). Perhaps the temp sensor at the bottom of the radiator can be removed, but this is not recommended since it will put a lot of stress on the radiator.
Old Sep 22, 2007 | 07:11 AM
malbojah's Avatar
Bottom bolt of the water pump on the left side of the bike is the drain for the whole cooling system
Old Sep 22, 2007 | 03:30 PM
collector's Avatar
As mentioned above and also below the tank to refill the system. Hope these help
[IMG]local://upfiles/10939/B87442DEF65C4E1CABD7F67C9A92B613.jpg[/IMG]
[IMG]local://upfiles/10939/B97E303E72CE4E03B894F5D0FC3F570C.jpg[/IMG]
Old Sep 23, 2007 | 04:12 AM
Coopz's Avatar
Ah great thanks, also what is it s capacity? The owners manual is a bit vague..
Old Oct 17, 2007 | 10:16 PM
Coopz's Avatar
edit: Still cannot find the cap... 99' model...help.
Old Oct 17, 2007 | 10:19 PM
HARDCORP 8654's Avatar
Friend and Hero ...
well you got the answer from three of the top five for knowledge in this section
Old Oct 17, 2007 | 10:24 PM
malbojah's Avatar
The cap or the drain plug?
The filler cap on 93- is located under the small fairing on the right side under the throttle tube.
The drain bolt is here:
[IMG]local://upfiles/5414/5BA51141118D4D03A9394F5104AF3A09.jpg[/IMG]
Chrisb319
May 15, 2012 02:02 PM
D4G
May 24, 2011 05:27 PM
Ride Red Bull
Jan 20, 2009 09:33 PM
rustler84
May 1, 2008 07:33 PM
9fiddyfo
Jan 20, 2006 10:56 PM
