Coolant change, stupid question?!
Old May 22, 2011 | 10:31 AM
D4G's Avatar
D4G
Default Coolant change, stupid question?!
Hi,
I have a CBR 600 F-T 1996
I am in the middle of doing a coolant change aided by my haynes manual.
I have drained the fluid from the drain bolt on the pump, and the manual goes on to say "once the flow of coolant has stopped from the pump, position the container beneath the front of the engine and remove the drain bolt from the bottom of the cooler casing"
ready folks? here comes the stupid question. I can't find the bolt the above paragraph is talking about (there are no pics of it in the manual) so if some one could tell me (or a pic would be even better) that would be great.
Yours stupidly,
D4G
Old May 22, 2011 | 11:09 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
i um. never used the drain bolts. i removed the clamp on the rad hose on the left side below the engine, and it all drained out there.
Old May 22, 2011 | 08:18 PM
Will.Bass's Avatar
same here. i didnt even know there was 1 drain bolt, let alone 2...
Old May 22, 2011 | 08:27 PM
pacemaker's Avatar
There you go.
Old May 22, 2011 | 08:55 PM
Will.Bass's Avatar
yea, think id still rather pull the hose tho. looks as tho there would still be coolant in the system after draining from that bolt..
Old May 23, 2011 | 03:32 AM
D4G's Avatar
D4G
There is thats why it talks about a bolt in the oil/coolant heat exchanger. but I can't seem to find said mythical bolt.
Old May 24, 2011 | 05:27 PM
jackojeff's Avatar
pull the hose on the left of the engine i did by accident(dont ask) and it drained all my coolant without having the engine on then fill with coolant easy as! forget this mythical bolt there is no need for it.
jamescbr87
F2 Tech
Jun 16, 2012 03:49 AM
Chrisb319
May 15, 2012 02:02 PM
Glocker23
May 9, 2008 11:31 AM
Coopz
Oct 17, 2007 10:24 PM
9fiddyfo
Jan 20, 2006 10:56 PM
