clutch bleeding woes
Old Jun 16, 2008 | 02:55 PM
dwarfdwarf's Avatar
Default RE: clutch bleeding woes
My clutch feels firm when you first start to pull it in then gets softer. The clutch also disengages shortly after pulling the clutch in.
Is it supposed to engaged more near then the beginning or when its pulled in all the way?
Old Jun 16, 2008 | 02:57 PM
dwarfdwarf's Avatar
UGh ive typed my post over 5 times already this is so frustrated
dwarfdwarf's Avatar
If I pump the clutch it will build up pressure
dwarfdwarf's Avatar
Is it true you can pump the clutch and then hold it down with a rubberband overnight with the MC cracked and that will help bleed it?
Old Jun 16, 2008 | 09:42 PM
Shadow's Avatar
Bleed from the bottom - not the top ! Yes, rubber band will help, but also stresses the seals.[X(]
Old Jun 17, 2008 | 09:25 PM
dwarfdwarf's Avatar
ORIGINAL: Dragon64
Hi
WhenI bleeded mine i ran in the same trouble, you need to unconect the hose at the cylinder lever, bleed the cylinder, once that is fine, reconnect thehose and bleed with the cable, there might be some dirt in there, it took me an hour to carry it trough and get rid of all the grit...
Old Jun 17, 2008 | 09:26 PM
dwarfdwarf's Avatar
where is the bolt hose at the cylinder level?? how do i bleed with it taken off?
Old Jun 17, 2008 | 09:27 PM
dwarfdwarf's Avatar
can anyone please explain?
dwarfdwarf's Avatar
I've bleed brakes and the clutches on my cars multiple times and I've never had any issues. I don't understand why the clutch isn't staying firm
Old Jun 18, 2008 | 02:24 PM
dwarfdwarf's Avatar
Am I supposed to be able to disengage the clutch by pulling it in with just my pointer/middle finger? The clutch completely disengages shortly after you pull it in
NateDieselF4i
May 10, 2012 05:06 PM
mpz
Jun 25, 2010 08:27 PM
swisherred
Jul 20, 2009 09:16 AM
old1000
Jun 10, 2008 06:11 AM
JeffRR
Apr 2, 2008 02:42 PM
