clutch bleeding woes
Old Jun 12, 2008 | 02:47 PM
dwarfdwarf's Avatar
Default clutch bleeding woes
I WISH I DIDNT GET MY POSTS DELETED
dwarfdwarf's Avatar
Default RE: clutch bleeding woes
I bled my clutch today and got all of the dirty fluid out of there
dwarfdwarf's Avatar
Now when I start to squeeze the clutch it feels firm, but as soon as I pull it in the clutch disengages very soon and the clutch feels soft
Old Jun 12, 2008 | 02:49 PM
dwarfdwarf's Avatar
I took the cap off the MC and cleaned out the dirt and flushed the fluid.
dwarfdwarf's Avatar
Now the clutch disengages after just pressing the lever in and it feels soft. I made it worse
Old Jun 12, 2008 | 04:00 PM
pfsnsd's Avatar
CBR Forum Help & Suggestion Center: https://cbrforum.com/fb.asp?m=584397
Old Jun 12, 2008 | 04:03 PM
pfsnsd's Avatar
You must have got air in the system somehow (that sucks ) you just got unlucky. The only thing I can think of is to rebleed the system, should work. Anyone else?
Old Jun 12, 2008 | 07:51 PM
bluebeard's Avatar
Agree. Re bleed. Make sure the fluid is the correct type for your bike. Probably dot 4 not the silicone stuff.
Old Jun 13, 2008 | 11:30 AM
DragonCBR's Avatar
Hi
WhenI bleeded mine i ran in the same trouble, you need to unconect the hose at the cylinder lever, bleed the cylinder, once that is fine, reconnect thehose and bleed with the cable, there might be some dirt in there, it took me an hour to carry it trough and get rid of all the grit...
Old Jun 16, 2008 | 02:55 PM
dwarfdwarf's Avatar
Is this the bolt I have to crack on the right? Will fluid come out of it? Do I just crack it and bleed my clutch normally?
