Changing cam chain
From someone who has recently gone through this I can give you a few pointers.
1. Dont atttempt it unless you have all the tools and a clean space to work on.
It you dont have these specialty bits it will make your life really hard.
Cam Chain splitter/riveter
Valve adjustment tool and 3mm hex Key
Good quality Torque wrench that can read accuractly as low as 8ft lbs
You will probably find that the cam chain you buy will be endless. But it will come with a spare link so what you have to do is split the new & old chain. Join chains, feed through motor and then join the ends up.
IF you do a search you will see that its been discussed in length on this forum (Including my dramas
Best of luck
Rob
)Best of luck
Rob
davedude44
Jun 28, 2012 12:22 PM
moosestang
Mar 4, 2011 05:35 PM
