Changing cam chain
Old Jun 15, 2006 | 07:58 PM
chuzbut's Avatar
Default Changing cam chain
My cam chain and tensioner is has now covered 60,000 miles and needs to be changed. Does anyone know how I go about this. IE does the cam chain need to be split etc.
Cheers Chuzbut.
Old Jun 15, 2006 | 09:42 PM
Trips's Avatar
Default RE: Changing cam chain
From someone who has recently gone through this I can give you a few pointers.
1. Dont atttempt it unless you have all the tools and a clean space to work on.
It you dont have these specialty bits it will make your life really hard.
Cam Chain splitter/riveter
Valve adjustment tool and 3mm hex Key
Good quality Torque wrench that can read accuractly as low as 8ft lbs
You will probably find that the cam chain you buy will be endless. But it will come with a spare link so what you have to do is split the new & old chain. Join chains, feed through motor and then join the ends up.
IF you do a search you will see that its been discussed in length on this forum (Including my dramas )
Best of luck
Rob
davedude44
Jun 28, 2012 12:22 PM
moosestang
Mar 4, 2011 05:35 PM
F4itanner
Mar 7, 2008 11:51 PM
bluestanger66
Jul 27, 2007 11:48 AM
will_f3
Jun 2, 2006 08:29 PM
