CBR1000F Ignition
Old Apr 10, 2013 | 03:17 PM
AlexP's Avatar
Registered Users
Exclamation CBR1000F Ignition
I have lost the key to my bike, so I need to take off the ignition and take it to a locksmith so he can make a new key for me, problem is when I went to take the ignition off I noticed it is held on by 2 TORX screws from the bottom, does anyone know what size TORX these are for sure? Is it a T-40? (just a guess)
Old Apr 10, 2013 | 03:33 PM
AlexP's Avatar
Registered Users
by the way it is a 1993 CBR 1000F
Old Apr 10, 2013 | 04:20 PM
Sprock's Avatar
news to me I thought it was an 8mm Socket Head bolt
90100-MN8-910
Old Apr 10, 2013 | 06:52 PM
AlexP's Avatar
Registered Users
I can confirm that the 2 bolts holding on the ignition are 2 T40 Security (star pattern) Torx Bolts. I went to AutoZone just now, bought a 3/4" ratchet ($9.99), a 24" extension ($13.99) and a T40 bit ($4.99) - got back to the house had the first one off in just about 30 seconds (have to go up from the front tire past the radiator) and I still haven't got the 2nd one off yet I think it is stripped now I am trying to figure out what to do.
Old Apr 10, 2013 | 08:03 PM
Sprock's Avatar
Well sounds like someone put them on as a replacement
Take a dremel and cut a slot or square it off for a needle nose vice grips
edit : carefully
Old Apr 11, 2013 | 03:52 AM
wheelnut's Avatar
Welcome Crew
if its being a real pain, i would unplug it from the loom, take the handlebars off and whip off the top yolk with the barrel still int it, it will make it easier to work on, you may be able to clamp it in a vice and use a chisel to take it out, wrap it up well though
Old Apr 11, 2013 | 04:49 AM
Sebastionbear1's Avatar
edit : carefully
Well I can tell you that the 1987 US import CBR1000F I have has torx bolts on the key ignition unit.
I know cause I had to tighten them.
Cheers, SB
Old Apr 11, 2013 | 06:52 PM
Sprock's Avatar
Interesting Seb - mine does not !
Maybe mines a replacement ignition switch !
Old Apr 14, 2013 | 06:50 AM
nutter's Avatar
this is the way to go mine is a 96 uk bike it had anti theft bolts on it from new
walivabuc
May 1, 2013 06:52 AM
Alex Poucher
Feb 14, 2013 09:29 AM
BottleFed954
Mar 14, 2009 07:24 PM
booger69
Nov 17, 2008 10:27 PM
bluestanger66
May 23, 2007 04:46 AM
