Carbie Frustration
Old 09-15-2008, 01:57 PM
bigape's Avatar
Default RE: Carbie Frustration
Didn't mean to offend anyone. But I did point out that I have the factory manual.
Anyway, I had a good ride yesterday. When I find some good fluid filled vacuum guages, I will go back to the 120s and try again.
Sometimes, I really wish it was fuel injected...
Old 09-15-2008, 02:13 PM
TimBucTwo's Avatar
If the butterfly is to open on #1 you will not get a reading. You may need to close it down. It would also be why it won't idle down.
You have to think of it this way, you are checking the vacuume between the intake valve and the butterfly. If you open the butterfly you are loosing vacuume. You need to back the screw out and close it down. If it is to open it is the strong cylinder and closing it will bring the idle down so you will aslo need to turn the idle adjuster in to conter act the closing of #1 butterfly.
In the state the carbs are in now #1 is to far open and doing all the work at idle. The other three carbs are to far closed and when you try to idle down with the idle adjuster the bike will die due to the fact that the other carbs would be fully closed at that point.
That is what may be happening or I just don't know what the heck I am talking about.
Old 09-15-2008, 02:15 PM
bigape's Avatar
You might be close. I did notice when I took the carbs off last time that 1 and 4 were open quite a bit while 2 and 3 were almost completely closed.
Aussie Johnno
07-12-2010 07:40 AM
Aussie Johnno
06-24-2010 12:59 PM
bluebeard
02-26-2008 07:14 AM
01nick929
09-26-2006 06:46 PM
Supersteve911
02-06-2006 01:59 AM
Quick Reply: Carbie Frustration
