Can the position of the rear brake pedal be changed?
Old Oct 1, 2007 | 01:27 AM
Flogger's Avatar
Default Can the position of the rear brake pedal be changed?
Hi everyone,
I find the rear brake pedal a little too high, can anyone tell me if these things are adjustable?
Many thanks
Phil
Old Oct 1, 2007 | 02:27 AM
Dean0's Avatar
Default RE: Can the position of the rear brake pedal be changed?
If you just want the end of the pedal to be lower - then YES - the link bar from the pedal to the master cylinder has a threaded adjuster. If you shorten the rod - the pedal will go lower.
If you want the pedal pivot point ( and footpeg ) to be lower - then NO.
Old Oct 1, 2007 | 06:07 AM
BLUE1000F's Avatar
I have a -90 (europe)model and mine was also too high so i adjusted the link and i also had to adjust the switch to the breaklight so it turns on at the right level/time. Just move the cowl...then you see how easy it is to adjust.
Old Oct 1, 2007 | 01:22 PM
Flogger's Avatar
Many thanks guys.....
Old Oct 1, 2007 | 09:41 PM
HARDCORP 8654's Avatar
Friend and Hero ...
Believe this must be a common problem. When I first got the CBR my was adjusted so high I could ride with the tip of my boot under the brake pedal. A bad habit to get into so I adjust it down as far as it would go and it is still just a little too high to suit me. But much better than it was
Ruaridh
Jul 23, 2013 10:36 AM
espelade
F3 Wanted
Sep 8, 2010 05:58 PM
iBang
Jun 15, 2010 11:21 AM
JJHUNSECKER
Sep 16, 2006 03:22 AM
