Brake question
Old 03-17-2008, 09:26 AM
Daniel.Hennessy@va.g's Avatar
Default Brake question
I removed the entire front left caliper to scrape out the grime. Replaced pads. Am having difficulty replacing caliper: piston caps keep sliding off, should they be adhesed in some way? Also, there is no daylight between the new pads and the rotor, should I have put the pads on after the caliper? thanx.
Old 03-17-2008, 09:27 AM
Default RE: Brake question
forgot to mention: this is an 87 Hurricane.
Old 03-17-2008, 11:43 AM
Shadow's Avatar
There are many other posts on this issue, but basicly the pistons are coming out too far - push them in, one at a time with a strong flatbladed screwdriver, and insert the pads, then pry the pads back far enough so the brake rotor will fit between them. Not too difficult.
wcarnold2
11-04-2010 05:28 PM
96@cbr
10-02-2009 12:00 PM
cpimp1264
10-15-2008 07:04 PM
Mafarlou
09-13-2008 10:48 PM
G3NESYS
03-31-2008 01:28 PM
Quick Reply: Brake question
