Bar Ends
Old Jul 6, 2008 | 08:26 PM
Oldest Sage's Avatar
Default Bar Ends
I've got a bar end that's got the threads buggered up...how do I remove the piece that's inside the handle bar? The threads are pulled out and I'm not able to pull it out.
Old Jul 6, 2008 | 08:43 PM
Shadow's Avatar
Default RE: Bar Ends
Can you not drill the hole one size bigger and retap it ?
Then use a helicoil.........
Old Jul 7, 2008 | 07:17 AM
Maybe if I knew what was inside the bar. The hole is pretty elongated, made from aluminum and appears to be only about 1/2" deep. It also appears to have a rubber outer sleeve which make me believe the mount screw may have to push on the dead end center and wedge the inside into the bar? I checked out a Clymer manual form the library and I can find no mention of the bar ends. The Honda mech's were of no help to boot. If someone has a diagram of it I may be able to figure out how to take it out and fix or replace it. If I have to replace it, is anyone using one of those locking bar ends? Would be a great place to lock the jacket when walking around.
Old Jul 7, 2008 | 08:43 AM
Shadow's Avatar
I think the inside looks like the ones shown here - when you tighten them, the rubber sleeve expamds inside the pipe. Over time, the rubber can attach itself to the inside of the bar, which may mean that to effect a proper repair, you may have to drill it out.[X(]
Maybe spraying some sort of light oil into the bar (Q20) may help free the thing.
I'm speaking under correction here, as I haven't been able to remove the inner sections from my bars...
http://shop.ebay.co.uk/?_from=R40&_n...ar+end+weights
Nope, never used locking ones.....
Old Jul 7, 2008 | 10:44 AM
TimBucTwo's Avatar
This thread may be of some help. I inculded a picture of the internals in that thread.
https://cbrforum.com/m_136312/tm.htm
Old Jul 9, 2008 | 09:49 AM
Shadow's Avatar
Here's a set for $30+ postage on e-Bay.UK
http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:B:SS:GB:1123
Old Jul 9, 2008 | 02:19 PM
Dave71's Avatar
At the end of the bars with the bar end off, peel the grip back and there is a small hole thats the locking clip holding it all in, press something in there and you should be able to free it, i lost a bar end going down the motorway and i found i had snapped the internals leaving a piece in there,i was lucky a friend had also lost 1 and had a complete internal and bar-end spare he showed me how it all came out and went back together again, its a lot simpler than it looks, i was getting ready to get the drill ind hammers out...
Old Jul 13, 2008 | 07:24 PM
Thanks for all the info so far. Mine is broken on the throttle side. I'll give it a try this weekend and let you know how it comes out.
murdocity
Jan 21, 2010 03:21 AM
DBEAU
Jul 15, 2009 09:54 AM
the dog
Oct 15, 2008 03:50 PM
barryem
Aug 10, 2007 08:58 AM
ptowntsi
Aug 2, 2007 12:46 PM
