Arc Welding
Old Mar 23, 2008 | 05:35 PM
GILL's Avatar
Default Arc Welding
I need to arc weld a frame bracket on the old girl and i ws interested in knowing if I need to unplug anything other than the battery beforehand so I dont fry anything.
Thanks all
Old Mar 23, 2008 | 10:17 PM
Shadow's Avatar
Default RE: Arc Welding
I would remove any of the wiring from the immediate area of the weld, and about 2" on either side I would wet newspaper, and wad it into a ball, and squish it onto the frame - this will reduce heat transfer down the frame to any heat-sensitive stuff, and reduce chances of warping as well.
My 2 cents worth.......
Old Mar 24, 2008 | 01:38 AM
R1000's Avatar
I would unplug the ECU that is behind the rear fairing on the right side.
Old Mar 24, 2008 | 07:32 AM
GILL's Avatar
Good idea and perhaps the R/R too while im in there....Thanks
Old Mar 24, 2008 | 11:51 AM
jb's Avatar
jb
aslong as you disconect the battery the bike is dead, no need for above unless your overprecausious
Old Mar 24, 2008 | 12:27 PM
R1000's Avatar
ORIGINAL: jb
It is a cheap insurance to disconnect the ECU. More than a few have smoked their ECUs in cars when welding. The welding current is very strong, houndreds of amps and high voltage spikes. The ECU is connected all around the bike and if it is reached by anything more than about 20 volts it may let out thebuilt in smoke. It can be enough even with a few volts to kill it to if it is reversed,which can be the result of ground current circuits that are generated when welding.
Sorry for preaching, didn't mean to be unpolite in any way.
Old Mar 24, 2008 | 12:37 PM
jb's Avatar
jb
point taken. link: http://books.google.co.uk/books?id=Y...9IYo&hl=en
C Average
F2 Tech
Jun 8, 2010 12:46 PM
Chrisct713
Nov 13, 2009 03:49 AM
01niceF4i
Apr 14, 2009 06:17 PM
bluebeard
Nov 8, 2008 06:22 AM
jahnaboi
Jan 15, 2008 01:32 AM
