Aftermarket Discuss aftermarket upgrades to your CBR here.
new Lights?
Old Aug 11, 2006 | 12:08 AM
azarmi44's Avatar
Default new Lights?
I know these are not anything exciting but does anyone know if these would be a decent replacement for the not so bright stock bulbs for an 05' CBR? Thanks!
http://cgi.ebay.com/ebaymotors/HID-H...temZ4636910998
Old Sep 25, 2006 | 01:09 AM
Ocelaris's Avatar
Default RE: new Lights?
Any bulb which is tinted blue absolutely is going to be worse for your headlights. No exceptions.
You ought to replace your bulbs after about 500 hours.. They make higher wattage bulbs, 100watts or the H9 bulb which apparently is a drop in replacement for H7, is 2100 lumens instead of 1400 lumens which is the factory H7 bulb.
http://www.rallylights.com/hella/H7.asp
CP64217 H7 Bulb, 12V, 65W, H9 Burner, 2100 Lumens by Osram, each $23.15
HL78174 H7 Bulb, 12V, 100W, each $13.02
But realistically, you have an H7 headlight, you ought to buy an OEM HID Ballast for about 60$ and an OEM HID bulb ~30$ and a H7 to D2S washer converter...
http://cgi.ebay.com/ebaymotors/Audi-...spagenameZWDVW
So for about ~100$ you can be out the door with 3500 lumens, nearly 3 times the light of the standard Halogen bulbs. That is what I plan on doing. Oh, you'll need a relay harness probably also, so that will run you about ~20$ if you make it yourself from radio shack parts. I plan on doing a write up at some point.
Old Oct 22, 2006 | 11:28 PM
Infamous_6969's Avatar
Anybody know of any Xenon kits that allow both bulbs to be on on the lowbeams. Rather than having to mod it? I wanna upgrade to Xenon/HID but dont want to have to mod to get both lights on w/ lowbeams
Old Oct 23, 2006 | 12:40 AM
D2VW14_20's Avatar
ModsExpress has a Group Buy for an HID kit in the GroupBuy section. I hear they are pretty awesome. Azarmi has PM.
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
