900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
03 to 02 954 engine swap
Old Sep 4, 2007 | 01:48 PM
k_hausser's Avatar
Default 03 to 02 954 engine swap
is it possible to swap a 2003 954 engine into a 2002 954. as well as some other parts like suspension brakes and fairings etc... im asking because i have a 02 900 which is getting tired and my friend has a complete 03 954 pretty much mint and is willing to swap everything to my bike real cheap. im sure it is possible but any main problems we might run in to.
Old Sep 4, 2007 | 03:40 PM
1badeg's Avatar
Default RE: 954 to 900 engine swap
02 900? Do you mean 929? 99 was the last year of the 900rr.
Old Sep 5, 2007 | 03:51 PM
k_hausser's Avatar
yeah i meant to put 2002 954rr not 2002 900rr! but anyway i have a 03 954 engine and im gonna swap it to a 03 954- theyre swap right? im sure they will but just double checking
Old Sep 6, 2007 | 08:03 AM
1badeg's Avatar
Yup, you will be fine with the swap.
Old Sep 23, 2007 | 08:48 PM
VP's Avatar
VP
the only difference between the two years is the head bearing on early 02s which was recalledand paint schemes otherwise they are completely 100% the same
Old Sep 24, 2007 | 11:57 PM
Flightmedic954's Avatar
you will find main problem to bethe insurance fraud charges
Old Sep 6, 2008 | 09:45 PM
skip954's Avatar
the steering neck berrings are different one is a ball berring the other is a roller setup.........also the forks are slightly different 03 seals wil not work on 02 mounting locations are the same diameter just keep in mind when looking for parts
ORIGINAL: vpsophmore
was the recall for head shake?
Mr. Bib
Nov 17, 2011 02:13 AM
bwiltrout
Jul 8, 2009 02:51 PM
hondaking69
May 27, 2009 07:39 PM
Workwell
Jan 14, 2009 10:02 PM
yellow_900_rr
Aug 16, 2006 01:11 AM
